Strange image on samsung syncmaster 245b
+ More Options
Posts
  • theo
    • Nov 2010
    • 3
    Hi to all!
    Firts let me introduce myself.
    I am Theo, from the Netherlands.
    I am working as a mechanic in a car garage an electronics is one of my many hobbys.
    At this moment my samsung syncmaster 245 stopped working and it looks the same like the attached image.(not mine) All collors are there but no normal screen anymore.
    Does anyone have a idea what could couse this behavior?
    Kind regards
    Theo
  • PlainBill
    • Feb 2009
    • 7034
    Re: Strange image on samsung syncmaster 245b
    Originally posted by theo
    Hi to all!
    Kind regards
    Theo
    Looks like a broken screen. Did someone knock it over, or hit it?
    PlainBill
    • theo
      • Nov 2010
      • 3
      No, it has always been on top of my computer.
      Never fallen or hit with anything
        09-07-2024, 05:50 AM
      • rattlesnake
        Samsung SyncMaster 955DF dim image fix
        by rattlesnake
        This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
        To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
        08-12-2023, 07:03 PM
      • shlomim412
        samsung ua55es6800 - no image
        by shlomim412
        hi
        having problem with samsung ua55es6800
        tv had backlight on, sound working - responds to the remote control but no image.
        check tcon board - had 12v in but no other voltages present.
        when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
        when leaving only left side connected - again no voltages and no image.
        put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
        kept trying to block less pins on the left ribbon cable...
        05-15-2024, 05:00 AM
      • soopacrucial
        by soopacrucial
        Hi folks,
        10-29-2024, 02:40 PM
        09-06-2024, 11:40 PM
