Gateway FPD1975W, display going black... Caps or Lamp?
  • Carbd86gt
    • Oct 2010
    • 4
    Hey guys,
    Read a couple of threads here from members who have problems with these Gateway FPD1975W monitors. My issue just started today. Turn the computer and monitor on, start browsing the net, and then all of a sudden the display turns off, but the power light stays on and lit solid blue. I turn it off and back on, and it comes back for about 10 seconds, then shuts off again. I recorded a video and took a picture of the power board.
    http://www.youtube.com/watch?v=VOA3XDlKFao
    As a note to the video, about 3-4 seconds before the display goes black, you can hear a light crackling, just like when you first turn the monitor on. It starts slow, then gradually speeds up then *poof*, it turns off. I then shine a light at the screen, and you can faintly see my wallpaper and even track the mouse across my dock icons and see the magnification of the icons. So, reading in some threads here, and reading info elsewhere, I could have 2 issues. Caps or Lamps. Attached is also a picture of the power board. There are no swollen caps, but I do see heat discoloration on the board near caps labeled C11 and C12 (Both branded Su'scon, 25v, 220uF). So, what is the diagnosis by you guys? Any help is greatly appreciated.
    Derek
  • Wrog
    • Oct 2009
    • 472
    Re: Gateway FPD1975W, display going black... Caps or Lamp?
    You're going to want to replace all caps on the power supply (if you plan on keeping this monitor for awhile) for starters, then if that doesn't resolve the issue then move on to the inverter drivers and CCFLs. What's on the bottomside of the board under the discoloration (probably the inverter driver transistors)? Since you hear a crackle, that's probably the ends of the CCFL arcing; you may either have a bad CCFL or bad wiring.
    • bonney
      • Oct 2008
      • 74
      If it's a 19" widescreen it's your CCFL tubes that power board goes in a Philips PHP which has the same problem
      • Carbd86gt
        • Oct 2010
        • 4
        Thanks Wrog. I should also note, that when I hear the crackling, the display is fine. Everytime I turn the monitor back on, the picture is fine. No discoloration, no flickering, and it turns on every time. I do plan on changing out all the caps anyways, was just checking to see if you guys may be able to pinpoint the root issue. I'll dig deeper today, thanks.
        • retiredcaps
          • Apr 2010
          • 9271
          Long shot, but the area around the 2 inverter transformers (T1 and T2) shows a lot of discoloration suggesting some hot components. I would flip it over and check for transistors on the backside and carefully check the solder joints.
          Even if they don't look bad, maybe resolder/reflow/touch up the transistors and all the transformer pins on the backside and retest?
          --- begin sig file ---
          --- end sig file ---
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
