Viewsonic VX2235wm
  • Eakster
    • Oct 2010
    Viewsonic VX2235wm
    Hello all, just posting this as a fun story.
    My lovely 22inch Viewsonic crapped out a few days ago. Black screen, power light on.
    I found this forum via a YouTube vid showing how to repair by replacing caps. Took monitor apart, spent 2 days gobbling up all this lovely info on the forum, learned all about caps, found where to order a set, took pics, reassembled to try the flashlight test. . guess what it works again
    The (CapXon) caps all appear fine. There is an odd area of corrosion on the top corner of the screen frame (top right when facing). It's never been wet, looks like that electrical type of corrosion. This tells me there may be an issue with the bulb?
    Not posting pics right now, don't want to waste bandwidth, will post for reference if requested, however you may see me again very soon...
    cheers!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Viewsonic VX2235wm
    We, here, always want to see pictures. It helps a lot.
    --- begin sig file ---
    --- end sig file ---
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • skelband
      Viewsonic VX2235WM-3 problems
      by skelband
      I am trying to diagnose an issue with the above monitor.
      Initially, I assumed that it was a PSU issue, but I'm not so sure.
      OK, here are the symptoms:
      Powering on the monitor, the backlight comes on, but there is no display on the panel. The power light is illuminated Blue.
      After about 3 seconds, the backlight goes off and the the power light goes Amber.
      I cannot get it to do anything with the buttons with either the blue or amber lights illuminated.
      If I plug in a VGA source, then the panel stays on indefinitely, blue light + backlight....
      02-15-2021, 02:56 PM
    • StefanNg
      Viewsonic VX2718-PC-mhd SG2701B01-8
      by StefanNg
      Hi, Badcaps.
      I am troubleshooting a monitor
      Viewsonic VX2718-PC-mhd.
      Panel model SG2701BSG2701-8
      Symptoms is no image.
      This panel has 2 panel board connected by a U-ribbon.
      When I disconnected the ribbon, I get a perfect half screen image.
      I took some test point voltage, when ribbon disconnected.
      HVAA 8.38v
      FVDD12 1.21v
      FDD33 3.3v
      VIN 11.79v
      VAA 16.85v
      VGHF 30.16v
      VGL -8.02v
      CK1_I ~ CK8_I 1.403v
      CK1_L ~ CK8_L 8.26v
      When I connect both panel board
      HVAA, VGHF, and CKx_L...
      05-17-2025, 01:43 AM
    • B2L_Repairs
      Huawei D15 no power found corrosion damage
      by B2L_Repairs
      I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
      02-06-2025, 01:05 PM
    • Traptor
      Logitech Z506 with corrosion
      by Traptor
      Hi Guys,
      I have a Logitech Z506 with some problem.
      The main problem was the front right and subwoofer gave a hard noise.
      After the disassemble I found many corrosion on the mainboard as you can see on the pictures.
      I removed the corrosions and the noise disappeared but the sound too.
      I think some parts is damaged because of the corrosion.
      I searched a lot on the internet but I cant find correct schematic for this pcb, so I dont know what is the correct values of the damaged parts.
      But I found same good pictures of this board.
      02-11-2023, 05:25 AM
