Lg 34uc97-s
  • MaC_ToC
    • Feb 2023
    • 31
    • France
    Lg 34uc97-s
    My LG 34UC97-S stopped suddenly and since then I can't get it to start again.
    After researching the solution would be to upload the bios only the only ones that I find are paying.
    Is there anyone among you who has this bios so that I can test?
  • flat-earther
    HP F4180 stopped working please help troubleshoot
    by flat-earther
    I was doing a large print job with my HP Deskjet F4180, and after about 50 pages the printer stopped in the middle of a page and the black ink light started flashing.
    So I went to refill the black ink cartridge with a syringe, but found out it still had a lot of ink.
    I tried to print a page again but every time it would print only a bit of the page and immediately stop with the black ink light flashing again.
    I tried two other black ink cartridges, and the problem still endured, so I knew this problem had to be with the printer itself.
    I ran HP Print and Scan...
    05-11-2025, 02:21 AM
  • tyler_jones8209
    2021 M1 MacBook Pro (A2442/820-02098-A) Stopped Charging on All Ports
    by tyler_jones8209
    So my friends A2442 MacBook Pro stopped charging one day and hasn’t worked since. It wasn’t like an immediate shut off, like it worked until the battery died but now she can’t charge it so idk what to do with it.
    I don’t have an ammeter (yet it’s coming soon) so idk if it’s doing anything funky with current or voltage but I know it doesn’t charge on ANY of the ports.
    I took it down to the motherboard hoping to see an obviously bad component but everything looks good.
    I don’t have much experience with laptops, only consoles and controllers...
    10-28-2025, 04:54 PM
  • thaphatmaster
    Dremel Li-Ion Charger Stopped Working
    by thaphatmaster
    This is my dremel charger for one of the Dremel / Bosch 10.8v (3s1p) Li-Ion packs. There are many like it, but this one is broken.
    It stopped responding the other day. No light when a battery is inserted, no voltage at the output when tested.
    The dremel itself and its battery are fine and working.
    Looking online, many people just replace this type of charger with an Aliexpress version. However most of the through hole components look straightforward enough to replace if they are broken.
    I'll do some basic poking about (continuity checks etc)...
    01-29-2025, 10:39 AM
  • Rangry
    Razer Blade 15 2022, No internal display, Error Code 43
    by Rangry
    Hi! I have a Razer Blade 15 2022, with a RTX 3060.
    One day, while using Linux, the internal display suddenly stopped working.
    On Windows, it says that the internal GPU has stopped working (with error code 43).
    I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
    I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting...
    05-29-2025, 07:01 AM
  • ezenia
    LUMIMAN Smart Bulb IC ID?
    by ezenia
    I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
    In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
    04-28-2025, 05:56 PM
