I've bought this monitor in 2004 when it suddenly started making loud poping noises and black smoke started venting out. I'm unsure if all of the parts are replaceable, so I posted some images to let all of you decide if only the caps need to be replaced or If I should get a new monitor .
Viewsonc vp201b repair help(pictures included)
Tags: None
Re: Viewsonc vp201b repair help(pictures included)
This is a prank, right?
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
1) Your pictures are huge and out of focus. To get the best pics, take your boards to a window on a sunny day and turn off flash and use macro mode. We need top view pictures like these ones in this post (mine)
https://www.badcaps.net/forum/showpo...94&postcount=1
Also we prefer them to be posted using this method.
https://www.badcaps.net/forum/showthread.php?t=1868
There is 2000x2000 size limit and a MB restriction.
2) The big cap lying on it side is defintely bad. It was manufactured in 2004 week 8 (0408 code). That was probably the bang. The good news is that you can easily replace it.
First, you need to measure its diameter and height. Then go to digikey.com (if you live in the USA) and search for a replacement following PlainBill's instructions at
https://www.badcaps.net/forum/showpo...33&postcount=2
Most will recommend that you also replace the remaining 5 caps on the power board.
3) If smoke came out, it would be prudent to check the fuse, bridge rectifier and other components to ensure they are not damaged. Do you have a multimeter? Are you experienced in using it to take readings?--- begin sig file ---
--- end sig file ---Comment
1. Sorry about the bad pictures, I have little experience in photography and they were too big to upload here so I used image shack instead
2. I checked that and I believe this would do the job?
3. I have a multimeter, but I'm not sure what those are.Comment
edit: If you are going to spend the money to buy the big cap for $3.29, you might as well change the 5 other caps on the power board. The total for the other 5 should be less than $3 USD. So for $10 USD or less, you have recapped the entire power board.--- begin sig file ---
by shelby5041hi
my neighbor gave me an old radio shack trs80 model3 computer...it was stored in his attic for 35yrs...i powered it on and after 5min lots of smoke was coming out of computer...i took it apart and didnt notice any fire evidence so i assume a cap split open...i looked around only saw 1 suspect part...see photo...could this be the smoke?1 Photo-
by Bubbsy 2002Hi to all, I was diagnosing 2 smoke detectors that experienced power surge. I opened one up and found a weird fuse/resistor, which now has open circuit. I can't find this part.
Forgot to mention they both light up and I believe the test function works, but when I put smoke to them no alarm!
Any help in this regard would be greatly appreciated.
Thanks,... -
by BehemotNot sure if this is the best section, so feel free to move it. I'm tasked to get some "safety device" in case something goes wrong to insure a dry sauna does not burn again. This time the wall with stove on it has been covered with mineral insulation material as well as linings. (Harvia states their stove can be mounted directly on wooden walls! get that!
Idiots wired extra (UTP, get that second time) cable to the sauna ceiling. Is there ANY smoke detector which could survive on the ceiling with up to 100 (120?) °C there, or just all those house toys...
by cntiHi.
BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
burned, measured 10M ohm.
QM801 [real PSU:...-
This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...09-12-2024, 03:36 PM
- Loading...
