Marantz SR4003 firmware request
  • aliougm
    • Oct 2021
    • 11
    • Taiwan
    Anyone can help ?
    I need SR4003 firmware to fix my AV set. Does anyone can provide me the latest version of the firmware ? Urge to request.
  • lotas
    • Jan 2016
    • 4763
    • Russia
    Re: Marantz SR4003 firmware request
    Originally posted by aliougm
    Anyone can help ?
    Firmware what CPU or DSP?
    • aliougm
      • Oct 2021
      • 11
      • Taiwan
      Hi Lotas,
      I need both of them if you have. Mainly my SR4003 MCU chip is burned. I need replace a new chip and then reload firmware. I realized CPU firmware it works for this MCU chip. Thanks ! ******
      Last edited by SMDFlea; 04-23-2022, 04:05 AM. Reason: Removed personal email address
      • lotas
        • Jan 2016
        • 4763
        • Russia
        Hello, I only have firmware on the CPU, how to program there is an instruction in the service manual for it.
        • aliougm
          • Oct 2021
          • 11
          • Taiwan
          Hi,IoTas:
          Appreciate your help, i can not wait to try. Will update you the result soon If it is able to save my AVR
          • aliougm
            • Oct 2021
            • 11
            • Taiwan
            Hi IoTas:
            Let you know, finally I updated the firmware successfully after a lot of hard work with new MCU. Thanks got your help again. Without your help I have no way to go. I used a USB to UART adapter to make it happened write this firmware to the MCU without use official updates hardware kit(from Marantz which discontinued product). I post some pictures here. Also share this results to contribute this forum for those who are dealing with AVR MCU.
            But additional problem is no HDMI no audio. I checked it is Sil9033 HDMI receiver chip is burned. I am working on that waiting for this ne chip arrival.
            • lotas
              • Jan 2016
              • 4763
              • Russia
              Thank you, I hope everything works out for you!
              • aliougm
                • Oct 2021
                • 11
                • Taiwan
                Hi, IoTAs.
                May I ask your advice? I’m trying to repair another set SR4003 AVR. “CHECK DSP ROM “ message came out while power on the set. I following the service manual to resolve ring DSP chip and EEPROM but nothing change. Could you have experience on that ?
                • Slapito
                  Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                  by Slapito
                  I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                  Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                  I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                  I already downloaded the BIOS update file from msi official...
                  10-09-2025, 02:00 AM
                • wattage
                  AOC AG493UCX 49-inch monitor - Firmware request
                  by wattage
                  Hello Badcaps Community,
                  The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                  07-13-2025, 04:41 PM
                • Daniel Larsson
                  Firmware file for Marantz NR1501 needed
                  by Daniel Larsson
                  I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
                  After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
                  The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
                  The content of these seems to be useless as far...
                  05-23-2025, 04:11 AM
                • aliougm
                  Seeking for Marantz DSP firmware SR4003 or SR6003 AVR
                  by aliougm
                  Anyone can provide Marantz DSP firmware for SR4003 or SR6003 AVR ? Or where I can to get it ?
                  05-09-2022, 03:16 AM
                • Bazilwrc164
                  Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                  by Bazilwrc164
                  I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                  The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                  I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                  If anyone can provide:
                  • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                  • Or a compatible EEPROM dump
                  07-23-2025, 12:15 PM
