Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
  • lcdcaps1
    • Oct 2011
    • 322
    Re: Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
    From My research i have found the transistor for q1314
    it is DTA143XKA or DTA143XUA, depending on package
    i cant find these anywhere
    which ones can i use as a replacement please
    thanks
    • R_J
      • 9558
      If Q1316 is shorted e~c that would explain why the motor is on. I would replace it, Q1314 is likely ok.
      The KA is larger, you need to measure the original to see which will fit the pads.
      • lcdcaps1
        • Oct 2011
        • 322
        Thanks for the reply
        I cant find anywhere that sells these
        Can you post some alternatives or compatibles ones
        Not sure if some values can be changed
        Thanks so much
        • R_J
          • 9558
          Digikey stocks both parts.
          • lcdcaps1
            • Oct 2011
            • 322
            Thanks for the reply.
            Are there any compatible or alternatives that I can buy from ebay or aliexpress
            Digikey I will have buy apps for free shipping
            Thanks so much in advance
            • lcdcaps1
              • Oct 2011
              • 322
              #26
              I know I only need one but if I order both at the same time I have them on hand just incase
              • lcdcaps1
                • Oct 2011
                • 322
                #27
                Would this be ok to use as an alternative if needed for q1314
                https://cdn.badcaps-static.com/pdfs/...f4c949429a.pdf
                Please let me know, all
                • R_J
                  • 9558
                  NO, that is a mosfet. Why do you think it is bad????
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    #29
                    Thanks.
                    My thinking is that when q1316 shorted it would have taken out Q1314
                    Because the emitter and collector shorted on Q1316
                    If I replace Q1314 and doesn't work it would be handy to have on hand to replace it
                    Could you advise of some suitable compatinle replacements please that is available on ebay or aliexpress. Thanks
                    • R_J
                      • 9558
                      Go to EBAY, then type DTA143X, There is a ad for 5pcs X DTA143X 340t-23 The picture shows DTA143XKA
                      All you need to do is measure the case on the original to know which part to order. They are electrically the same, just the foot print is slightly different.
                      Q1316 likely shorted do to high current in motor, maybe the mechanism jammed causing the motor to stall and draw excessive current
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        #31
                        Hi
                        I can't find them
                        Can you recommend some other ones please
                        • lcdcaps1
                          • Oct 2011
                          • 322
                          #32
                          Hi
                          I can't find them
                          Hi
                          I have sourced some
                          I will order them
                          hopefully they arrived soon
                          • sbt123
                            charnwood w821 mini wood lathe motor problem
                            by sbt123
                            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                            10-27-2024, 03:43 AM
                          • Joho
                            HP PRODESK 600 G2 DESKTOP MINI starting, no picture, fan only spinning faster and faster
                            by Joho
                            Hi there, I've got a HP Prodesk 600 G2 Mini on my bench, that turns on but no picture.
                            Model: HP ProDesk 600 G2 Desktop Mini
                            Product No: Y3J22EC#ABD
                            BID=15WWP3ET6**#SABD#DABD
                            Serial: CZC632BBCJ
                            First I thought maybe BIOS got corrupted. Someone sent my corrected BIOS that I flashed. Now symptoms are: Mini starts when power is plugged in, Fan turns on and gets faster and faster until it's at 100%. Nothing gets excessibly hot.
                            When I desolder the BIOS chip I get Beep codes / LED codes "BIOS is missing"
                            Without CPU I get "CPU...
                            03-07-2025, 09:18 AM
                            HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                            This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-12-2024, 03:36 PM
                            HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                            This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                            09-12-2024, 02:20 PM
                            09-12-2024, 02:15 PM
