behringer ulr 2000 error 5
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    i have the above wireless system and when take power supply appears the error code 5 and after shut down
    Does anybody idea whats going wrong ?
  • petehall347
    • Jan 2015
    • 4451
    Re: behringer ulr 2000 error 5
    5 = battery is fully loaded
    page 16
    https://www.manualslib.com/manual/21...page=16#manual
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      and why the receiver shut down sir ?
      i must unplug 12 volt power supply plug again i have the same condition
      error 5 and the receiver shut down
      • petehall347
        • Jan 2015
        • 4451
        i cant find the service manual .
        you could email the makers and ask about the code ..failing that good clear pictures of the circuit boards might help
        • Xristakis795
          • Mar 2021
          • 162
          • Greece
          ok sir thanks for the help
          • sanalelevenstar
            Yamaha RX-V485 receiver. After encountering a "version error"
            by sanalelevenstar
            I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
            After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
            I managed to find the service...
            09-10-2025, 01:54 AM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            Replaced emmc.
            Terminal log
            UART
            AC_ON
            E-B
            FDE enabled
            06-01-2025, 02:11 AM
          • titomno2
            Dell G3 3590 SELEK_N18E_MB error 2000-0314
            by titomno2
            I have a Dell G3 3590 ( SELEK_N18E_MB 18812-1) and the Nvidia GPU is permanently deactivated following error 2000-0314.
            Basically it say the thermistro GPU is out of value (cold start It ready 120°C permanently).
            I need help to understand what piece of hardware may have failed and how to replace it as everyhting was working fine and the thermal paste was removed and replaced by PTM7950 properly.
            All schematics are available on the forum and if someone could be able to help me and give me direction on what component to check first.
            I found THM261 on the back of...
            10-17-2025, 05:23 AM
          • sushilachuthan
            APC UPS error P13
            by sushilachuthan
            one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
            the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
            The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
            We replaced the SCR with new device,, but the device is not power on as expected.
            Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
            09-26-2025, 09:00 AM
          • CdDvdFlash
            Hitachi HTA-DD3W AV Receiver Error Code -Protect-
            by CdDvdFlash
            I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
            07-10-2023, 06:05 AM
