roberts dab mpsound 43 circuit
  • jimbofz
    • Apr 2013
    • 539
    Hi ive searched internet for cct diagram of sound o/p stage using TPA3100D2 ic.no luck
    in manufacture they pour hot melt glue over the top to secure the inadequate heatsink .problem is it carbonises and when removing (carefully),to expose the pins of this 48 pin ic some of the very small surface mount components come off with the goo..
    some sony tvs use this ic kdl3500 model .their cct leaves me puzzled as many external components are completely different .
    the sound via headphones is fine as it uses separate 8 pin ic
    theres sound going into the tpa chip and all supplies ok ,but not a peep of sound replacing this minature ic would be a chalenge as a number of close components would have to be removed to gain acess with solder station
    has anyone done battle with one of these ?or any other brand that may use the same ic? roberts technical is a joke ,no help at all .the sound on these is very good when working ok ,so its worth my time trying to repair. thanks
    • 31305
    Re: roberts dab mpsound 43 circuit
    you dont get luck if you use the devil's search engine - you get targetted marketing.
    if you use yandex you get this:
    https://www.ti.com/product/TPA3100D2
    although i already knew it was a Ti part because it started with "TPA"
    • jimbofz
      • Apr 2013
      • 539
      thanks STJ ,been using that info,
      mute pin 45 low ok
      vreg pin15 4v ok
      shutdown pin 44 high ok
      vbyp pin16 1.25v ok
      avcc supply 10v ok
      fault pin 46 low ok
      pvccl 10v ok
      pvccr 10v ok
      i/p left and right healthy waveform ok
      no measured s/c across o/p ,l/s both fine
      so unless i can find out from cct diag the correct values of the surface mounts
      im snookered
      • jimbofz
        • Apr 2013
        • 539
        the sangean ddr 43 , 62 , and 63, look the same product
        any ideas for servics manual /cct diagram ?
        thanks
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • edugimeno
          Help me identify the missing component... Sound to light circuit
          by edugimeno
          hI there!
          Im trying to help a friend repairing a large, real-sized short-circuit robot.
          This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
          Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
          What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
          So I bought a simple 2X30W amplifier to feed the loudspeaker...
          02-14-2024, 10:23 AM
        • LEECH666
          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
          by LEECH666
          Good day ladies and gentleman!
          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
          01-19-2024, 05:46 PM
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:30 PM
