Fostex CR500 Master Recorder.
  • gazman321
    • Sep 2021
    I've been asked to take a look at a Fostex CR500 Master Recorder, I cant find the service manual online.
    Does anyone have a copy of the service manual or know if the CR300 uses the same PCB layout?
    Symptons that have been described to me are that the machine powers up, then continuously is pulses off and on.
    Thanks.
    DVR recorder Switching power supply Failure
    When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
    Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
    This...
    05-27-2023, 03:03 AM
  • stormanimal83
    Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
    by stormanimal83
    i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
    08-04-2024, 01:47 AM
  • The WABBIT
    Dell Inspiron 5559 need BIOS Master PW
    by The WABBIT
    I had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
    After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
    Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...
    07-12-2021, 04:20 PM
  • 66Ton99
    Gigabyte Z790 Aorus Master Schematics Request
    by 66Ton99
    I have a problem with my Gigabyte Z790 Aorus Master, it doesn't run now.
    Looks like I damaged some elements
    But I do not know what's there.
    Please help....
    07-11-2025, 01:56 PM
  • Ady2017
    Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
    by Ady2017
    I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
    06-06-2025, 08:05 AM
