Need help with 4700uf 25v replacement in subwoofer
  • jayjr1105
    • 281
    Bought a cheap sub on marketplace for $20. Has two 4700uf 25v Jun Fu 85c rated caps. I've found several replacements for around $1 or 2 but what ripple current rating should I shoot for minimum? Also they have to be 16mm wide and a max of 30mm tall, lead spacing is 7.5mm and they are through hole.
    I am about to buy these just because they're cheap and 105c rated
    https://www.arrow.com/en/products/47...er-electronics
    Edit: add some bad 22uf 25v Jun Fu's to the list as well
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    • 31294
    Re: Need help with 4700uf 25v replacement in subwoofer
    i wouldnt bother,
    your not hitting the caps with high frequency's
    if you do replace them you need high ripple current handling.
    • rustinjust
      Please help, subwoofer connected to tv, read description below
      by rustinjust
      I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
      Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
      Is there a way of...
      10-28-2023, 07:09 AM
    • rustinjust
      Please help, where can I get a remote for my subwoofer?
      by rustinjust
      I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
      Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
      Is there...
      10-28-2023, 03:43 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • h0m3w0rk
      Repairing a Music Store Professional GO! SUB 18A
      by h0m3w0rk
      I'm working on repairing a Music Store Professional GO! SUB 18A bass subwoofer, and I need some help troubleshooting an issue with the power amplifier board. The board uses an IR2153 driver and originally had two SLW20N50C MOSFETs. Unfortunately, these MOSFETs burned out. I replaced them with two TK20J60W MOSFETs; however, these also failed almost immediately.
      Here are some details:
      • SLW20N50C (original):
        • Rated for 500 V
        • Typical RDS(ON): 0.21 Ω
        • Continuous Drain Current: 20 A at 25°C (13 A at 100°C)
        • Pulsed Drain Current: 80 A
        • Avalanche
      02-27-2025, 07:42 AM
    • the_rem
      Unknown transformer : how to find a good replacement part ?
      by the_rem
      Hello guys,
      I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
      I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
      04-23-2025, 01:48 AM
