Boss DD-3 Repair (low volume)
  • Camarada78
    • Jan 2021
    • 28
    • Brazil
    I have in my bench a first generation Boss DD3 delay pedal from the 80s or early 90s.
    it was dead. I managed to get it to power on again but the fx volume is too low.
    it can be heard when i play the guitar but its suttle, a faint delay on the background, even with everything on max setting.
    First i thought of a bad coupling cap, but i dont know, checked a few of them (there are many on the audio path) and so far nothing.
    Am I missing something stupid?
    have a goood day
  • CG2
    Janome DC3050 Sewing Machine Pedal Resistance
    by CG2
    OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
    Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
    04-14-2023, 07:53 AM
  • karthur
    Vizio D65x-G4 Volume changes on its own
    by karthur
    On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
    It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
    06-05-2025, 08:13 AM
  • Camarada78
    Boss delay DD-3 (square ship taiwan) problem
    by Camarada78
    I have a Boss DD-3 (square chip taiwan version) in my bench with a very weird problem. I found no similar problem online, nor a solution for it. It is driving me nuts.
    It passes sound on bypass no problem but as i turn it on it has a constant a noise (that can be clearly shaped by Delay Time, Volume and Mode, but very subtle by Feedback).
    - sounds ok on bypass
    - noise is there even without input connected.
    - all electrolitic caps were changed (!)
    - all tantalum caps were checked, ok.
    - most ceramics were cheked. too many to keep track....
    05-08-2023, 07:44 AM
  • freethink
    Kenwood KR-A70 Receiver Balance changes with volume controls?
    by freethink
    I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
    11-23-2025, 07:53 PM
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
