Old Pioneer Amp - Waveform explanation
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Re: Old Pioneer Amp - Waveform explanation
    According to the schematic I think the component is a 2SC2291.
    I need to visualise the actual device and confirm it.
    If it is the above, where would I i find one? - or a substitute?
    Edit: The device is a C2259
    • redwire
      • 3910
      The STV2H diodes I mentioned in post #4 are well known to fail with age and cause bias problems in vintage Japanese amplifiers.
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        make up the dual packages with 2x KSC1845FTA each package .
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          Many thanks Pete and others. That's a great solution.
          • redwire
            • 3910
            The transistor pair's beta need to be well matched if you're replacing the 2SC2259's and expecting low offset voltage.
            At this age, I would replace the few electrolytic capacitors in the power amp. They can cause large DC offset i.e. C409, C419 if they are shorted or leaky.
            • dreamlayers
              Weird clipping on Logitech Z-10 speakers
              by dreamlayers
              I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
              05-22-2025, 11:41 AM
            • Bushcat
              Pioneer PL-X9 motor speed control wobble
              by Bushcat
              I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
              Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
              BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
              05-24-2023, 03:36 AM
            • technodruid
              Wavetek 130 Output issues
              by technodruid
              First post!
              Last night I finally got a chance to try out a wavetek 130 that I purchased a year ago or so after finally getting unpacked from a move. It was working really well, I was testing the various settings from the 50 ohm output into my rigol scope and it seemed to be fairly accurate. I was stepping through the course adjust from x10 to x100 and sweeping the dial looking for any distortions or drops/rises in amplitude. It all looked great.
              Then when i switched to the 1M setting, the sine wave disappeared. I moved back to x100k and the sine wave was still gone. Something...
              04-04-2024, 10:32 AM
            • EduCabral
              [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
              by EduCabral
              I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
              While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
              🔧 Details:
              • Model: YT-M06
              • Interface: Pioneer 1
              • MCU: Fujitsu MB89F202
              • Goal: Find a valid .bin firmware file or memory dump from a working unit
              I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
              07-15-2025, 12:26 AM
            • pixelcap
              Pioneer Kuro Pro 111FD 8 red blink error
              by pixelcap
              Pioneer Kuro Pro 111FD 8 blink red LED.
              I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
              So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
              based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
              10-06-2024, 11:26 PM
