Onkyo TX-NR353 clicks no display
  • kubax
    • Dec 2020
    • 6
    i've got a Onkyo TX-NR535 AV-Receiver that does not power on.
    It only clicks and nothin happens. Not even the Display is lit up short.
    I can force it to power up "completely" if i remove the power connector to the AMP Board (the one directly from the transofmrator) OR if i unplug the HDMI board from the vertical board (leaving any cables connected)
    The vProtection and iProtection both are at 0,5v measured through the vias beneath the CPU and using ground from the P9001 connector
    The problem stays even with the preAmp Board removed. I suspect the problem be either on the HDMI Board or the Amp Board, but i can not find any obvious problems.
    Any ideas what i could test?
    Service Manual:
  • kubax
    • Dec 2020
    • 6
    Re: Onkyo TX-NR353 clicks no display (UPDATE: Check Speaker Wires)
    Now i'm a litle bit further, but iritated aswell.
    I did try to measure the Power Transistors in circuit, but the readings were strange. So i did unsolder every one of them and measured of circuit.
    Here are my measurements.
    Code:
    1:
    CE = OL
    CB = 13m Ohm
    BE = 13m Ohm
    Diode Mode B+E- 0.57v, B+C- 0.57v all other combinations OL
    2:
    CE = OL
    CB = 10m Ohm
    BE = 11m Ohm
    Diode Mode B-E+ 0.56v, B-C+ 0.56v all other combinations OL
    3:
    CE = OL
    CB = 11m Ohm
    BE = 11m Ohm
    Diode Mode B+E- 0.56v, B+C- 0.56v all other combinations OL
    4:
    CE = OL
    CB = 11.8m Ohm
    BE = 12m Ohm
    5:
    CE = OL
    CB = 12.9m Ohm
    BE = 12.9m Ohm
    Diode Mode B+E- 0.58v, B+C- 0.58v all other combinations OL
    6:
    CE = OL
    CB = 13m Ohm
    BE = 13m Ohm
    Diode Mode B-E+ 0.58v, B-C+ 0.58v all other combinations OL
    7:
    CE = OL
    CB = 9.8m Ohm
    BE = 9.8m Ohm
    Diode Mode B+E- 0.54v, B+C- 0.55v all other combinations OL
    8:
    CE = OL
    CB = 11.2m Ohm
    BE = 11.5m Ohm
    Diode Mode B-E+ 0.54v, B-C+ 0.54v all other combinations OL
    9:
    CE = OL
    CB = 9.5m Ohm
    BE = 9.5m Ohm
    Diode Mode B+E- 0.54v, B+C- 0.54v all other combinations OL
    10:
    CE = OL
    CB = 12.2m Ohm
    BE = 12.5m Ohm
    After testing with every Transistor removed, i got at least some seconds of display before shutting down.
    So i soldered every Transistor back on, and did test in between every single one to see if the problem reoccurs... To my complete surprise, it did not go of instantly as before.
    I completely rebuild the AV Receiver to see if it changes when everything is in place, including some of the screws to the back plate to have ground distributed to every board.
    Now the receiver stated "Check Speaker Wire" the first two times turning it on, and then returns to the previous behaviour of only clicking... I found that resetting the AV Receiver cycles this process.
    Now at least i have a Display, but i don't know where to look next -.-
    I think the unsoldering of the Transistors did the same as resetting the device with CBL/SAT + Power. It might have done this in the first place, if i would have known the key combination in advance...
    Oh, and resetting the device does not seem to work with the pre amp board removed. Wich did led me to think the problem might be there, but the Transistors and foild caps measure good, i think (foil 4nF)
    • kubax
      • Dec 2020
      • 6
      Now i did get it to boot properly, but have no clue why. All i did was measuring the components on the preAMP Board, and putting everything together. I had a speaker connected to Center to test with FM / AM if there is any sound, but did not have any (but i also did not have a antenna). After some seconds i did turn it of and noticed a litle electronic smell... The Power Transistors of the SL channel are hot like hell. although there was no heatsink attached, but to my understanding as there is no speaker connected the transistor should not be powered. the other ones were room temperature.
      • madan1
        • Nov 2016
        • 682
        The power amp transistors are always powered and kept active. Still, it is not normal to get hot without actually producing any output signal.
        See service manual - debug mode / service menu.
        It will show you why the unit is entering in protection mode ( turning off ).
        • kubax
          • Dec 2020
          • 6
          Ok, the problem is almost fixed.
          The problem must be (or must have been?) on the SL part of the AMP board. The two Transistors Q6063 and Q6053 were the ones getting hot, untin they suddenly didn't get hot...
          I tested with my multimeter and these two transistors suddenly had close to 0 Ohm resistance. So they are blown.
          At first soldering them out didn't fix anything.. no sound but running fine. So i did check a litle on the AMP Board, and found that both Fuses were blown. As i did not have 10A Fuses (or 125v) laying around, i did put in two 250V 5A Fuses until the ones i ordered right now arrive (currently all except food stores are closed because of a pandemic lockdown here in germany).
          Trying to play a mp3 from a USB stick, i get sound on every channel except SL, but because of the missing Transistors thats fine, i guess :-DD
          I also ordered the two transistors (3 x each) so replace them, and see if the problem reoccurs. I doubt that only the Transistors were bad, but i can not find any other problems in the ciruit for now. At least i have some replacements then
          i will report back when the replacements arrive...
          • kubax
            • Dec 2020
            • 6
            Just wanted to report back, the Receiver is working now on all channels.
            Replacing the two Transistors fixed the problem. Although i have no idea why they measured ok, but seem to be defective.
            Thanks for you help
            • FrancescoV
              Onkyo HT-R390 no sound output, video output ok
              by FrancescoV
              Good morning everyone,
              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
              The firmware reported is the following:
              M:1.00/11107BLP
              D:?.??/????????
              O:1.00/11107AL
              The DSP firmware given the question marks seems corrupt.
              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
              05-11-2025, 02:59 AM
            • GRANDGG
              LG 42lw4500 flashing red light , wight light , 2 clicks
              by GRANDGG
              Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
              05-09-2025, 12:27 PM
            • waterboy1602
              Onkyo TX-SR507 stuck in standby mode/protection mode, relay clicks one time
              by waterboy1602
              I would be really happy if someone could help me with this problem. I'm already trying for longer then a year with on and offs to fix this problem.
              I have an Onkyo TX- SR507 (schematics added) that is stuck in standby mode. The red light is on if I connect it to the net. When I press the power button I hear a relay clicking. The relay clicks just for one time and then the red light goes back on.
              I had a blown capacitor (C6040)and shorted transistors (Q6050, Q6060) at one channel from the receiver. I replaced R6100, Q6050, Q6060 and C6040. Is there something I missed?...
              06-14-2019, 02:05 PM
            • ahoonid
              A1708 820-00840 No boot - trackpad clicks - 20V 0.55amp
              by ahoonid
              Hi everyone.
              I have MacBook Pro A1708 with a confusing issue.
              The laptop doesn't turn on. Strangely, the trackpad clicks and fan spins. Caps lock doesn't turn on and no chime.
              Initially, the amp meter didn't turn on at all on one of the usb c ports. On the other port, I got 20V and half an amp tho (no battery connected).
              I replaced the bad CD3215 chip and now it works as well. Both ports turn on with same amp readings.
              The initial issue however remains.
              No boot. No backlight. No chime. No keyboard. Only signs of life are clickable trackpad...
              05-10-2025, 04:19 PM
            • zahi
              DSP dump BIN files for ONKYO TX-NR5009
              by zahi
              Hello everyone, I need DSP dump BIN files for ONKYO TX-NR5009, TX-NR3009, Integra DTR-80.3, PR-SC5509, DHC-80.3, DTR-70.3, I think also 5007 is the same, or other...
              I have replaced the DSP chip, still not working.
              Can you share please?​
              04-25-2025, 04:32 PM
