Akai am-u03 integrated amplifier
  • GEARELECTRONICS
    • Apr 2019
    • 13
    • seychelles
    Amp has both output IC STK0040ii blown and removed.
    Can I use this amp as a preamp with out the STKs and if I do will this cause any problems.
    your kind answer will be very much appreciated
    Thanks in advance
  • petehall347
    • Jan 2015
    • 4426
    Re: Akai am-u03 integrated amplifier
    shouldn't be any problem so long as there are no other problems
    • GEARELECTRONICS
      • Apr 2019
      • 13
      • seychelles
      Petehall347 thanks for your reply i appreciate
      • Sik_6ty_Sixx
        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
        by Sik_6ty_Sixx
        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
        02-18-2025, 05:06 AM
      • rooprob
        a rare beast: The Scotland-made Ariston Integrated Amplifier.
        by rooprob
        Hi there
        Total noob here.
        I have been hanging on to learn more about diagnosing and fixing amps, and watching a lot of youtube.
        This one is the Ariston Integrated Amplifier. There's no model number.
        I didn't find many references online: https://www.worthpoint.com/worthoped...made-174132328.
        I've owned this one for about 15 years. It was working fine, and was put away for a long time. Today the sound can be described as crunchy. You can clearly hear music, but it's very clipped and distorted.
        When...
        04-27-2023, 04:17 AM
      • jinu_j
        How to test Subwoofer Amplifier with only a multimeter
        by jinu_j
        Hi Folks
        Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
        Problem
        I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
        Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
        Any advice would be appreciated...
        08-29-2024, 02:05 AM
      • UserXP
        Mackie CR4 amplifier no sound
        by UserXP
        Hi, people.
        I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
        Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
        10-17-2020, 05:06 PM
      • mikey5791
        Help on car amplifier only one channel works
        by mikey5791
        Hi all forum members,
        Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
        My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
        08-06-2025, 10:36 PM
