Denon RCD-M40 "Protection Mode: Power", couldn't reset.
  • JidhinGeorge
    • Jun 2017
    • 7
    • United Arab Emirates
    I have this Denon RCD-M40 with protection mode: power ON always! I cannot reset and I can't use the system by any means! Anyone has a fix? There was line voltage fluctuations for the past couple of days and is now fixed. The receiver was working fine even after that on reset but now this error again and stays ON all the time, right away on plugging the power cord.
  • 3Phase615V
    • Feb 2014
    • 6
    • United Kingdom
    Re: Denon RCD-M40 "Protection Mode: Power", couldn't reset.
    I don't know your experience level but based on the limited description of the fault symptoms and the fact the receiver appears to intermittently work, I would check the voltages on the supply rails while testing for dry joints (flexing the PCB). You may be able to reproduce the fault at will and identify the area that needs attention.
    If you can obtain the service manual or at leas the schematic it would be useful.
    • JidhinGeorge
      • Jun 2017
      • 7
      Thanks for replying, I have the service manual and I did a solder reflow yesterday to all the individual PCBs after taking apart each boards and the fault cleared, worked for a day. But on turning the power ON today it went bad again. Same fault. Attached service manual to the post here.
      Thank you.
      • JidhinGeorge
        • Jun 2017
        • 7
        Is this could be a weak capacitor, the culprit? I have this feeling since it worked fine for several hours and then I removed the main power overnight and plugged in the next day to see the error again!
        • petehall347
          • Jan 2015
          • 4429
          • United Kingdom
          could be heat related
          • JidhinGeorge
            • Jun 2017
            • 7
            I suspect that too, so where to start with? Any suggestions?
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • MyBrainIsAStrainer
              Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
              by MyBrainIsAStrainer
              Hi!
              I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
              Symptoms in detail:
              1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
              2. I press power button. The board boots without issues.
              3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
              4. Push power button again, board boots fine.
              5. This shutdown/powerup can be repeated multiple times without problems.
              6. BUT: If I do a restart instead
              06-25-2023, 02:44 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
