Kenwood KR-A5080 Amp.
  • computerbob
    • Sep 2009
    I have a Kenwood KR-A5080 amp that when you turn it on the front panel
    comes on for about 5 sec. and then the amp shuts down. Can anyone tell
    me what to look for?
    Bob
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Kenwood KR-A5080 Amp.
    What you always look for in a failing amp power supply problems (bad caps and regulator ICs) and shorted audio output transistors or ICs.
    Open it up and take some pics. I don't know what you expect to hear from a a few sentences? Give us some details .
    • DrDos
      Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
      by DrDos
      Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
      08-08-2025, 03:16 AM
    • huzo
      HP Omen shuts down when loading OS
      by huzo
      The model is 15ec-1061nm
      Board number is DAG3EDMB8D0​
      SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
      10-29-2024, 12:05 AM
    • Giggle2562
      Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
      by Giggle2562
      I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
      The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
      Here's what I've tried so far:
      • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
      • The laptop shows an image on the internal display for a few seconds before it shuts down.
      • I tried swapping the LCD panel with a known good one.
      • I tried swapping the LCD cable
      11-06-2025, 12:36 PM
    • riko 656
      Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
      by riko 656
      I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
      Laptop Model:
      • Model: Lenovo Legion Slim 5 16APH8
      • GPU: NVIDIA GeForce RTX 4070
      • Main BIOS chip size: 32MB
      • VBIOS chip size: 16MB
      Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
      What I Have Tried So Far:
      1. I
      11-04-2025, 05:14 AM
    • Mark R
      The Overseas Only Kenwood Model KR 790
      by Mark R
      I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
      The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
      09-23-2025, 08:27 PM
