Marantz NR1504 No sound
  • nyogo
    • Dec 2018
    • 6
    • Hungary
    Hi all.
    I got a used Marantz NR1504 AVR with a firmware problem. The amp was stuck in a "update failed-retry" loop, possibly failed when the owner tried to update the fw over the internet.(Marantz/Denon well known issue)
    I managed to break the loop and updated the firmware from usb.
    The problem is that no sound coming from the speaker nor the headphone output. I tried different versions of FWs from usb also updated over net with the latest fw. Nothing changed.
    Everything works fine btw: front display menus, web GUI, relays switching during power up and when plugging headphone.
    When switching to Test Tone to set up speaker levels, only the front left speaker sounds, but only the test tone nothing else.
    So I started to check everything based on the service manual(btw its really well documented):
    - tried to reset different times/different parts (ucom, lan contrl., stored configs etc) to rule out sw problems
    - checked all power rails: within 5% all levels are ok: 12V-7V-3.3V, etc
    - not really seeing visually bad components/parts
    - switched to service mode where I can just operate "blocks": when the Analog signal block is selected and should the signal pass through, still silent everything
    - amp board working fine when feed with ext. signal via onboard connector (every channel)
    - internet radio/tuner mode when it should play something coming from the DA/DSP on the HDMI board, I got signals on DA_FR,DA_FL (CN5202) so I assume DA/DSP and main controller is OK(checked with oscope)
    So I suspect the something on the analog/AV board is gone. There is only a R2A15218FP analog mux IC on it with few other parts(attached the board scheme).
    The problem is that the HDMI/DSP board is on top of the AV signal board, connected with vertical PCB boards so cannot measure anything on it when powered up.(Marantz has official flex cable kits for repair, but I don't )
    I already ordered a new mux chip, but I really love to hear any ideas, since I'm not a professional and never repaired things like that.
  • madan1
    • Nov 2016
    • 719
    Re: Marantz NR1504 No sound
    All analog inputs go directly to R2A15218FP. There are two upstream channels ( ADINL ADINR ) which go from the R2A to the HDMI board for processing. You should be able to test the signal on that two upstream channels on the connector between the boards.
    If you select pure/direct audio, the R2A15218FP stops using the upstream channels and passes the analog audio directly to its output channels.
    By the way, you can see this on page 36 from the SM.
    So, check if the R2A is passing the analog audio to the upstream channels ( if you can't access the connector, you should be able track the traces on the hdmi board ).
    If there is upstream audio, but then there is no downstream ( on DAFL, DAFR and so on ) then you have a problem on the HDMI board.
    If there is no upstream audio, then the IC is not working properly or is not commanded properly by the CPU.
    You can check if the analog signal is reaching the IC by simply checking the continuity from the input terminals to the ICs pins.
    Did you check if the R2A has the necessary power supply ( +/-7V most likely ) ?
    • nyogo
      • Dec 2018
      • 6
      • Hungary
      Thanks, this is a good idea with the up/downstreams, i'll check it.
      The +/- 7V is present (~±7.2V) and testing with pure/direct audio on, there is no analog signal coming from the R2A (at least measuring on the connector which goes to the amp board).
      • nyogo
        • Dec 2018
        • 6
        • Hungary
        Ok, now I'm a bit of confused.(and sad, because looks like there is another problem than R2A)
        After a few days I had time to measure the up/downstreams. The receiver was unplugged from the power outlet for days.
        So, first I switched to an internet radio and there was sound on the speakers also on the headphone. (First a little distorted, but after a few minutes it became OK)
        Switched thru the dsp sound modes, checked each channel downstreams, and there was signal on the lines and sound from the speakers.
        Then I tried the analog inputs. The upstream at ADIN_L/R is ok, but there was no signal on the downstream lines. Direct audio/pure audio on and still no signal, also there is no sound from the speakers.
        Now the "funny" part: switched back to internet radio and the sound is gone, also the downstream signals.
        So...I plugged out the receiver and back. It started to play the internet radio, but there was no sound until I pressed the dsp "sound mode" button.
        If I switch to another input then there is no sound(even switch back to internet radio) and also no downstream, until I plug out from the mains.
        If there is sound, it is distorted (lack of bass, little bit fuzzy).
        I assume this leads back the problem to the HDMI board. Also based on the sound I hear it's similar to when the signal line has contact problem.
        I think I'm gonna start checking around the DAC (PCM1690) and trace back the signals.
        • madan1
          • Nov 2016
          • 719
          Check again the power supplies for ripples.
          p.s. keep in mind that the internet radio and the USB music ( not sure about the second tho, check the SM ) do not go directly through processing. They have their own D/A converter and have a dedicated stereo downstream to the R2A. Then if needed ( like if you have selected some kind of an audio processing ) they go through the stereo upstream to the HDMI board.
          • nyogo
            • Dec 2018
            • 6
            • Hungary
            15V, +/-7V,5V main lines are ok(clean, straight line) measured on the board connectors.
            Checked the four EX4AV DC-DC converter, 1.1-1.2-1.8-3.3V good, measured on the "output" caps. I checked the voltage on the few big electrolytic caps on the DAC's power lines, the supplies were ok.
            But...there are a few caps near the DAC(on the VCC1/VCC2 and VDD lines) and I cannot reach them, because it's under the HDMI board along with the DAC chip
            So for now, at least I know that the source where the voltages are created is clean.
            Tomorrow I'll try to measure the power supplies directly on the chips' vcc pins.
            • madan1
              • Nov 2016
              • 719
              Oh, and just for the fun - when the issue occurs, get in the service menu and check the firmware versions of the different components.
              Also, try applying heat to the BGA chips on the hdmi board ( not reflowing, just warm them up ).
              • mmartell
                • Oct 2013
                • 3189
                Not saying this is your issue but...
                I have here an SR5008 for which the sound disappears at times, other times it is there with varying amounts of noise and yet other times perfect.
                If I HIT the right side at the rear with my fist I can induce one or another of these same symptoms. If you google you will find many Marantz owners with similar symptoms. I can even find a service bulletin covering a few models (not yours or mine however...)
                So in my case it looks like a sketchy ground somewhere in the signal path. It has yet to be disassembled.
                I would rule that out before you go nuts chasing your tail.
                • nyogo
                  • Dec 2018
                  • 6
                  • Hungary
                  madan1: the weird thing is it doesn't matter that there is sound or not, the service menu always shows the correct fw version of each component. Also, when there is sound, I can switch through all DSP sound modes, so the internet radio should go through the DSP chip.
                  The BGA heating would be my next step, but first I'm going to check all connections/grounds and audio traces on PCB, because it looks and sounds like a cracked solder joint or PCB trace.
                  mmartell: thx!I'll definietly check it out.
                  • FuzzyOwl
                    Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
                    by FuzzyOwl
                    Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
                    Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
                    Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
                    I've followed the trouble shooting guide, audio check...
                    12-05-2024, 11:54 AM
                  • acedogblast
                    Marantz SR5012 popping and other sound issues
                    by acedogblast
                    Hello I have a Marantz SR5012 7.1 AV receiver that is producing speaker pop and other sound issues. These sounds are coming out of all connected speakers regardless if they are configured to be used. The rca preouts are clean from these defects so I am assuming the problem has to be with the amplifier.
                    These sound issues are random and unpredictable. There are times where the unit can go 10 minutes without any problems then suddenly the problems come back. It doesn't seem to matter if there is sound being played or not.
                    I have disassembled the unit and was able to take out the...
                    02-15-2023, 01:40 PM
                  • Benass
                    Marantz NR1601 No Sound, Schematics attached.
                    by Benass
                    Certainly! Here's a revised version of your text:
                    I own a Marantz NR1601 receiver, but unfortunately, I'm experiencing an issue with no sound coming from any of the outputs. I'm seeking assistance to identify the most likely cause of the problem.
                    The unit powers on without any issues and seems to be functioning properly. I've noticed that the relay clicks after about 10 seconds, indicating that it's going through its startup sequence. There are no visible signs of damage, and I don't detect any burnt smells.
                    While the schematics provided...
                    03-11-2024, 03:00 PM
                  • benspawn02
                    Anthem MRX500 - no sound. R2A15218FP issue??
                    by benspawn02
                    Dear Electronics Experts:
                    I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                    08-12-2023, 04:46 AM
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
