Russound CAA66 - Very soft volume
  • henryvrensburg
    • Oct 2018
    • 104
    Hi guys
    I have a Russound CAA66 Controller Amplifier installed in my house. It worked very well until one good morning. It still kind of works, but the volume is very low. You can hear the source, but it is to soft. You also can't increase the volume.
    I also observed that when you try to increase the volume on the panels, it does show the volume going up, but the Sound still stays soft. It's as if the Amplifier is in "limp mode"
    I removed all speakers and inputs/panels leaving only one set of speakers and pane, same result.
    Do someone have some ideas. Thank you
  • redwire
    • Dec 2010
    • 3912
    Re: Russound CAA66 - Very soft volume
    I would check the programmed settings, there are volumes for each zone/room. Are they all low volume?
    I'm not sure if you have an auxilliary power amplifier(s) on Zone 1 or Zone 2 which could act as master volume setting(s). Those power amps themselves probably have their own volume controls too, so those might be muted or set low.
    Kind of have to know what stuff is connected to it. It (CAA66) looks like a basic volume control, muting seems to mute completely, if it was on or the doorbell/paging trigger stuck on there would be no sound.
    CAA66 manual
    • henryvrensburg
      • Oct 2018
      • 104
      Currently the setup is as follows:
      Technics Radio is source
      6 x KPL-LCD Keypads
      6 x zones
      Nothing else is connected to the Russound, I've checked for mute on the Technics, I also tested with another source. It might be in the settings, it's just strange that it worked one day, and the next it 's not. You can hear what song is playing, it's just to soft. When you try to up the volume on the Keypad, the Keypad shows the volume going up, but it doesn't get louder
      • redwire
        • Dec 2010
        • 3912
        I would compare other zones, it might be a (blown) shorted speaker or speaker wiring. Once, I had a contractor put a nail thought a cable and short it out.
        It was hard to find because the speakers can be wired in parallel.
        If you have a multimeter, you can measure ohms on each zone's speaker (at the Russound terminals). I'm not sure how many amplifier channels are in it, it must be six, so are they all quiet?
        If the speakers test OK then the settings might be scrambled or the CAA66 has a hardware problem. Someone might have had a party and changed settings.
        Otherwise, I'd contact Russound for suggestions.
        • henryvrensburg
          • Oct 2018
          • 104
          All channels got he same volume level.
          Thank you Redwire, I'll test the Speaker ohms for each zone and post again.
          Thanks again
          • henryvrensburg
            • Oct 2018
            • 104
            Hey guys
            I tested the resistance between points on the speaker cables. All tested round about the same. The speaker cables have 4 cables, red, black, white and light green. Between the red and black measures around 8,2 ohms and between white and green the same. Some speakers are a bit less at 7,3 or 7,8 ohms. I opened the cover of the Unit, checked all CAPS or regulators etc. Could see no visible damage.
            I thinking of connecting just one panel, one speaker and one remote controller, the try again with one source.
            Any other ideas
            • petehall347
              • Jan 2015
              • 4440
              try it with minimum requirements as in inputs and outputs . if no joy try different input source to rule out that .if no good try factory reset if it has one .
              • crackedprint
                Sony HCD-HX80R Amplifier Volume Control Problem
                by crackedprint
                I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                I have tried a Cold Reset as per the service manual.
                I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                I have looked all the way through the service manual and tried many online...
                01-21-2025, 12:18 PM
              • BigOof
                Marantz SR5007 popping on volume change and mute in Direct Mode
                by BigOof
                I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                12-12-2024, 06:15 AM
              • Dannyx
                Simple volume control for audio amplifier ?
                by Dannyx
                Good day folks. I want to run a Bose subwoofer and some random speakers on my PC at home. I don't have an amp for this project yet and I was looking for decent solutions and I figured I could very well run them on a car amp. Why not a regular hi-fi amp ? I figured a car amp would fit better under my desk. I looked at a Sony XMN1004 which is relatively affordable, yet of decent enough quality and with good reviews overall. Conveniently enough, this Bose Acoustimass 5 Series II sub (what a name) I have has two drivers inside, each with its own separate terminal, so I can hook it up to the Sony...
                12-27-2020, 10:17 AM
              • FuzzyOwl
                Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
                by FuzzyOwl
                Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
                Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
                Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
                I've followed the trouble shooting guide, audio check...
                12-05-2024, 11:54 AM
              • Storyteller12
                Samsung Soundbar Q900T Cuts Off if Volume above 30
                by Storyteller12
                I have this soundbar and when I turn it on it works until I turn the volume above 30.
                Then the display show “PROT” protection and shuts off.
                I can turn it right back on and it works until volume hits 30 again.
                There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
                I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
                It will play fine for hours with volume...
                03-21-2023, 12:31 PM
