Technics SU-V9 recap
  • TechnicsHiFiFan
    • Mar 2018
    • 13
    My Technics SU-V9 would run perfectly then when i used it again the relay would not kick in, replaced the thyristors, and noticed one of two of the caps had green fungus on one of their legs.
    pre drive board has a few caps as does the main board
    Ive used Nichicon PW, Wima for values under 1uf, and Panasonic SU for the one bi-polar? maybe i should have used Nichicon EP?
    Pre drive board not sure, the VCC/GND caps. I am thinking low esr over Audiograde caps but fear to change the sound. The V9 was sounding a bit on the bright side so maybe something was wrong with it
    The large main capacitors are 18000uf 56v and look fine and flat, not sure to change them or not. If so maybe CDE 380LX or UCC SHM or KMH?
    pre drive board i had to seperate the image as it was long
    thank you
    Sam
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8331
    Re: Technics SU-V9 recap
    Yep, these caps are toasted. They leaked all over the place. You have to get that cap juice off the board, so clean that really good. In which position were those caps in? BTW, if I'd had that for repair, I'd be doing a full recap
    • TechnicsHiFiFan
      • Mar 2018
      • 13
      Thank you Capleaker for the reply
      Yes they are on the main board, the top one is the V9, the pre drive is fine the caps but i would expect since i am doing the mainboard have to see what to use there?
      mainboard mix of PW and FR ( maybe should have gone all PW and Wima) Main caps look nice and flat not sure if they have any issues
      pre drive board caps fine here going by my eye. Again if I did the main had some bad caps, maybe is wise a full recap , very few caps with the V9
      • madan1
        • Nov 2016
        • 722
        Get few out of the board and measure them.. if they read good, leave them ( at lease this is what I'd do ). Pay more attention to caps from the power supply circuits and near to heatsinks.
        • TechnicsHiFiFan
          • Mar 2018
          • 13
          Thanks Madan1
          The pre-drive board the topside faces the heatsink
          recap power ciricuit with FR. and PW. Not sure if I should have it all PW
          image from the net from the front of the V9, the pre drive board faces the heatsink, space between cap top and heatsink would be about 1cm - 2cm
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
            by momaka
            03-15-2023, 10:17 PM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • fl0w
            GeForce 6800GT recap, need help identifying caps and finding replacements
            by fl0w
            I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
            But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
            I need to replace:
            • 2x 2.5V 1500µF => I plan to use this
            • 2x 16V 330µF=> I plan to use this
            • 1x 6.3V 680µF=> I plan to use this
            Am I correct with the cap choices?
            Thanks for...
            10-02-2024, 11:28 AM
