Help making a simple audio amp
  • evilkitty
    • Nov 2017
    • 299
    I have a pair of old JBL 145SSAT Speakers
    I made a cable to use them with a 3.5mm jack
    I have it hooked to a low profile dell pc
    I think it needs more amperage to preform optimally
    How can i use a USB port to get more power to it?
    I have some 2n2222a, 2n3906 and tip120 (NPN Darlington) transistors to work with as well as some diodes and resistors
    I also have a few caps i can use to smooth out any supply fluxions
    I am not trying to make a external volume control, just something so i can use the computers volume control to adjust it, i just want enough juice to drive the speakers properly
  • madan1
    • Nov 2016
    • 690
    Re: Help making a simple audio amp
    Get one of those http://www.dx.com/p/pam8403-dc-5v-cl...e-green-347324
    • evilkitty
      • Nov 2017
      • 299
      Thanks, i'll give one of those a try
      • evilkitty
        • Nov 2017
        • 299
        This worked out great, though that is only when using some SFF dell box, when i hook it up to a decent desktop i get a lot of static and noise from doing anything like moving the mouse or dragging windows around, any good way to solve that or should i just use a filtered power adapter instead of the system's USB ports
        • madan1
          • Nov 2016
          • 690
          get a dedicated sound card or an external usb sound card
          • samson7point1@yahoo.com
            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
            by samson7point1@yahoo.com
            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
            The player processes the audio signal using two different reference frequencies. The "R"...
            04-30-2024, 11:22 AM
          • i_am_patch
            Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
            by i_am_patch
            Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
            04-30-2024, 08:20 PM
          • MOSSEP
            Monitor Audio RSW12 - Green light but no audio
            by MOSSEP
            Hi
            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
            I have already tried replacing all of the...
            01-26-2025, 08:18 AM
          • grimacelord
            MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
            by grimacelord
            I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
            12-11-2023, 11:13 AM
          • chbalnuweit
            HP 840 G5 Shorted Audio IC
            by chbalnuweit
            so I made a stupid mistake and dropped a screw onto the motherboard while assembling it.
            The screw fell right onto the battery connector area and unforunately managed to short one of the supply voltage lines of the Audio IC (Conexanct CX 7750) without me noticing at first.
            After the assembly and booting Windows I noticed that there was no sound and no Audio IC detected in device manager...
            I got the motherboard out again and found the Audio IC with a crater in it...
            Luckily I got a donor board with the same model motherboard....
            11-19-2023, 12:12 PM
