Sony mds JA 30 ES minidisc
  • Koprol
    • Sep 2017
    • The Netherlands
    I have a fantastic but faulty machine from my brother. It's build like tank but is quite complex with a lot of pcb's and a complex disc mechanism.
    I would like to repair it.
    I understand most of you don't know this machine but it is "just another" electronic apparatus so you might be able to help me find the problem.
    The loading tray wasn't working properly. I replaced the belt and that's solved.
    Another problem occurs when the machine get warmer. When it is in my "cool" workplace it plays perfectly but in my audioset it sits above a warm poweramp. First the display goes black but the machine continues to work. Some time after that (30 min) it stops playing and doesn't accept minidiscs and spits them out again.
  • jons
    • Feb 2014
    • 59
    • Latvia
    Re: Sony mds JA 30 ES minidisc
    That sounds like cold solder somewhere, in power supply most likely. Check first hot components like regulators/diodes.
    • Koprol
      • Sep 2017
      • The Netherlands
      Ok, thanks.
      I was going to search on the display pcb because the fault is is there first and then progresses to more areas. When writing this, your suggestion sound logical than mine...
      • jons
        • Feb 2014
        • 59
        • Latvia
        Still, check that displayboard also. There can be some more colds. Sorry for late answer, don't come here too often.
        • Vitosev
          • Sevilla
          hello, I'm having the same problem, when it's on for 30 minutes it's a strange thing and it's stopped, it does not open the tray, what was the solution? thank you very much
          • Longbow
            • Jun 2011
            • 623
            Since the symptom can be reproduced, just get out your heat gun and find out what part of the unit is sensitive to heat. Or wait for failure and selectively freeze various things. Better than guessing at least for now. Usually mechanical things work better when they are warm, so I would suspect electronics first.
            Is it plugged in?
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
              ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
              This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:28 PM
            • CG2
              Janome DC3050 Sewing Machine Pedal Resistance
              by CG2
              OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
              Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
              04-14-2023, 07:53 AM
            • dkneyle
              Sony KDL-46HX850 Can't upgrade/update firmware
              by dkneyle
              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
              09-25-2024, 10:44 PM
              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 05:27 AM
