Sherwood SEL-200
  • jazzie366
    • May 2016
    • 304
    Sherwood SEL-200
    Hey guys! I have a Sherwood SEL-200 old solid-state reciever. I absolutely LOVE the way it sounds, except one of the outputs is going bad. The problem is, they're only marked with "S200" and were made by RCA for Sherwood, they've been rebranded. I can't seem to find what they are so I can replace them properly. There are 4 of them. If anyone knows where I might find an old parts list or some substitute, I'd be amazingly thankful. I want to use for a home audio system.
    Thanks!
    Popcorn.
  • BigPete
    Intermittent display on Sherwood Newcastle R-965 Receiver
    by BigPete
    I'm working on a Sherwood R-965 at the moment. It came in with relays clicking constantly and also going into protect mode.
    I've re-soldered a lot of dry joints and replaced quite a few capacitors and now it works, but I still have one problem I haven't solved and would like some opinions.
    The vacuum display is quite intermittent. Sometimes it won't turn on, sometimes it will turn on but the characters, numbers and letters are frozen on, regardless of which buttons are pushed. And sometimes it works flawlessly. If the display doesn't turn on initially, restarting...
    08-25-2024, 02:48 AM
  • Jodeanss
    Infinity sub amp and Onkyo 2 ch reciever
    by Jodeanss
    Hey all, looking for some advice
    First i have an Infinity sub amp from a ps10 that turns on, makes buzzing noise louder and louder till it shuts itself off. Noticed someone on ebay fixes them so it must be quite common.
    Anyone have any idea on what goes out on these?
    2nd i got a 2 ch onkyo tx8050 reciever that has never had any speakers hooked up, it was used as a controller for an old bose 5.1 amp they sold way back in the day, so only thing used was the 2ch preouts fed from the optical from tv. It turns on with half dim display and then protects...
    04-04-2023, 08:07 PM
  • NecroFlex
    Need fan error removed from BIOS Lenovo S200 10HQ
    by NecroFlex
    Hello, i have 2 of the same machines, the 1st one is dead, it is plagued by this issue (same board model):
    https://www.badcaps.net/forum/troubl...=4#post1606399
    So it's not worth saving (flashes lenovo logo for a sec, then reboots to a black screen), the 2nd one only has the fan error that stops it from booting unless you press F1. I'd need the error removed so that the system...
    10-17-2024, 06:44 AM
  • ddhlawi
    bios lenovo all one s200
    by ddhlawi
    hi
    i need lenovo bios all one s200 ec and main
    AIA30 LA-C671P REV1.0
    im testing this file but not work
    https://www.badcaps.net/forum/showthread.php?t=70090
    my file...
    07-28-2022, 04:26 AM
  • Crystaleyes
    Tenma (Farnell-rebranded) 21-10115 solder station question
    by Crystaleyes
    Olá.
    Looking for some help clarifying something.
    I have a Tenma (Farnell-rebranded) 21-10115 solder station which recently burnt out the ceramic element.
    The station is 60W / 28 volts, 110v.
    Right now I'm in Brazil and finding an equivalent element has proved to be not possible, so today I bought a 'Yaxun' 50W 24v iron in the hope that it would work.
    Both irons have a five pin plug.
    The Tenma had pins 1 & 2 and pins 4 & 5 shorted with pin 3 being the ground. No means of measuring the temperature.
    10-19-2021, 08:08 PM
