M-Audio GSR18 speaker, powers on but no sound.
  • Xandros
    • 66
    • England
    This is a big powered sub, it appears to power on ok (lights come on) but there's no sound from the speaker, not even crackling/pops/hissing. I took the actual speaker out and tested it passively using another amp and it did output music I played (all be it very quietly but as I say I only tested it passively) so that seems to work.
    The sub has been used outside a lot and it seems to have been stored in somewhat cold/damn conditions. When I took the circuitry out to have a look I could see straight away there's lots of corrosion on many of the metallic parts and around some solder joints and there's some sort of residue (likely from damp) in places on the PCB.
    The caps all look sort of ok I guess, no apparent leaking or bulging, except perhaps for one of the big ones (bottom left in the third picture). It does look ever so slightly bulged but I can't really tell if actually is or if it's just my eyes playing tricks. And there's a small one not far from it that looks a bit suspect (4th picture). Beyond testing voltages I can't do anything else (no oscilloscope) so I post here on the off-chance any of you pros could shed some light on it.
    I haven't had any luck locating a schematic for the thing either. M-Audio haven't made these speakers for years apparently.
    Thanks in advance!
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: M-Audio GSR18 speaker, powers on but no sound.
    If you don't have an oscilloscope available, do you have any (other) test equipment?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Xandros
      • 66
      • England
      Only a multimeter. It has a few useful capabilities but it's nothing special.
      To be honest I was hoping for an easy fix, like I'd pull the board out and see something obviously wrong with it such as an exploded/leaking/buldged cap or two or perhaps broken solder joints that I could easily touch up but beyond the corrosion there doesn't seem to be anything visibly wrong with it. I knew right from the start if it was anything more complex wrong with it I was going to be out of my depth. Total hobbyist here you see.
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        do you hear the relay click ?
        you can build a signal tracer with a .01uf capacitor and use your working amp to listen .
        • Xandros
          • 66
          • England
          I don't hear anything when I power it on, no clicks or buzzing or... Well anything. Also I can't use the other amp though, it was just a small thing from a stereo we used to test the speaker that wasn't mine and I no longer have access to it (not for a good few weeks anyway).
            https://www.badcaps.net/forum/attach...0&d=1491561338
            It looks like one of the transistor pin (next to c73) is not soldered proeprly, some for the one next to c69 (I know it is double-sided board so it may make contact on the bottom side). So you should look really close at the boards.
            I also need good straight shot of the top and bottom side of the board to see how the power relay is driven.
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              pic 2 ..
              q1 looks strange and what is that above it ?
              d6 looks wonky but might be ok .
              also see some solder joints that might be bad .
              i also noticed the big transistors arent sitting flat on the heatsink .pic 6
              • Xandros
                • 66
                • England
                Good spot, they do seem soldered properly on the underside though;
                Here's as best shot I can get with my phone camera top and bottom of both boards with a couple of closeups:
                pic 2 ..
                Not sure. There are a few splodges similar to it dotted across the board, it seemed to wipe off and didn't appear to be damage to the PCB under it. A not so focused closeup:
                There's this weird splodge too on the other board;
                Yea any unsoldered spots I'd seen seem to be soldered on the underside OK. Also with the big transistors I think that's just because I'd already unscrewed the clamps that were holding it down as I'd already looked at the underside of the board so it wasn't sitting flush when I took those pictures.
                  I will give test points once I look at all the pictures.
                  Looking at the bottom side of the power supply/power amp board, that black power relay should come on when the unit detects the incoming audio otherwise it will stay in standby mode so the power supply is running at very low level until the relay is turned on.
                  So for sure you do not hear any clicking sound coming from the relay?
                  This is going br tough to trace because it is double-sided board.
                  • Xandros
                    • 66
                    • England
                    Not a thing, even with audio being piped into one of it's two inputs it just sits there quiet as a mouse.
                      https://www.badcaps.net/forum/attach...6&d=1491649247
                      See that U3 (not used) is ? Check the DCV between cold side GND and Pin 4, cold side GND and pin 8 to see what you have.
                      BTW, you know how to count the pins of the IC, right?
                      • Xandros
                        • 66
                        • England
                        I think so but just to be sure; I looked at the IC next to it which has a stripe on one side as do the other chips in the vicinity and based the pin layout on them.
                        That right?
                          That is correct pinout for the IC.
                          • Xandros
                            • 66
                            • England
                            pin 4 seemed to hover around 1.03v, pin 8 hovered around 0.61v
                              You are sure that meter is good? What did you use for GND ref. point?
                              If it is, then those OPAmp ICs are not getting the +/- DCV run.
                              • Xandros
                                • 66
                                • England
                                Yea I must have done something wrong. I just did it again, now both pins are reading 2.6v or there abouts.
                                Sorry about that! Not sure if that makes any difference though, but anyway I guess before with the other readings I must have knocked the meter onto a different range or something. This time I made sure it was on dcv autorange and just let it do its thing. As for the ground, I'm using the earth wire as cold ground, presumed that was right since it's attached to one of the screwholes/chassis.
                                  Check the resistance between pin 1 and GND, pin 2 and GND on the input board.
                                  Check the DCV between the two legs of each one of those two caps (marked in the picture) on the power supply/Amplifier board.
                                    I expect about 12~15VDC.
                                    See post 17.
                                    • Xandros
                                      • 66
                                      • England
                                      Hello, sorry for the extremely late reply. I went on holiday around Easter and have been really busy since I got back and sorting this thing out has been an afterthought. But anyway I got around to testing the resistance today and it just keeps reading OL on those pins and gnd. Didn't bother with the caps yet.
                                      Unless OL was an expected result, then I think you may be right and my meter's kaput. Yet another thing goes wrong when I'm trying to fix something else. Story of my life that is.
                                      • Xandros
                                        • 66
                                        • England
                                        OK so, after another lengthy absence I've finally done the tests you suggested.
                                        Resistance between pin 1 and gnd is 3.270kΩ and pin 2 and gnd is 2.950kΩ
                                        I tested the voltage of those caps, one reads aprox 20v the other is approx 19v.
                                        Cheers.
                                        • cazi1001
                                          Samsung Galaxy A22 - strange problem with sound / speaker
                                          by cazi1001
                                          I have a Samsung Galaxy A22 5G with a strange error image.
                                          If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
                                          If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
                                          If I listen music via Youtube, even the upper or lower speaker don't work.
                                          If I switch louder or quieter, the sign on the screen show me a headphone.
                                          If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
                                          Does anyone have any ideas, what the problem could be?​
                                          02-10-2024, 09:16 AM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
