Car Audio Amp not working...
  • nelers
    • Oct 2016
    • Bosnia & Herzegovina
    Hello guys,
    Yesterday I got some car amp from my friend, it's "Pioneer GM620 - (EW version)". There are two RCA plugs for input audio signal and 4+4 connector (GND, ACC, ILLUMINATION, one unused; L+, L-, R+, R-). I have power supply which I usually use to test car equipement.
    I connected ACCU and ILLUM wire together on (+) terminal and GND to (-) terminal. Also, two audio out wires from connector to speaker and from RCA plug I used PC speakers cable (3.5mm to 2xRCA male) to connect amp on my phone. So, I played some random song on amp, but I can hear no music on it. Nothing. Not even some cracks out of speaker...
    I've checked amp datasheet, found my model GM620 - EW version and it seems that everything is connected as it should be, according to the schematics provided. *I provided a pdf with datasheet of amp in attachments.
    What do you think guys? Maybe I did something wrong, or there is faulity on the pcb... If there is faulity, how can I spot it?
    Amp's PCB Back
    Amp's PCB Front
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • i_am_patch
    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
    by i_am_patch
    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
    04-30-2024, 08:20 PM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:18 AM
  • grimacelord
    MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
    by grimacelord
    I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
    12-11-2023, 11:13 AM
  • chbalnuweit
    HP 840 G5 Shorted Audio IC
    by chbalnuweit
    so I made a stupid mistake and dropped a screw onto the motherboard while assembling it.
    The screw fell right onto the battery connector area and unforunately managed to short one of the supply voltage lines of the Audio IC (Conexanct CX 7750) without me noticing at first.
    After the assembly and booting Windows I noticed that there was no sound and no Audio IC detected in device manager...
    I got the motherboard out again and found the Audio IC with a crater in it...
    Luckily I got a donor board with the same model motherboard....
    11-19-2023, 12:12 PM
