Sony MHC-RG20 Mini hifi system.NO sound
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    This Sony Mhc-RG20 has no sound but the audio IC appears to be ok because
    when the power is switched on,the system does not go into protect mode.There
    is a relay on the main board and it appears that this relay is not functioning.
  • Longbow
    • Jun 2011
    • 623
    Re: Sony MHC-RG20 Mini hifi system.NO sound
    ...then, the unit is probably in protection. Is this a speaker relay? Why not have a look at the voltages on the "in" side of the relay?
    Is it plugged in?
    • SEAWOLF
      • Nov 2011
      • 177
      This is a speaker relay and the voltages on the "in" side of the relay is 12.8 volts.
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • intrax
        sony mhc-2600 mini hifi restoration...
        by intrax
        Trying to restore a sony hifi mini set mhc-2600. Board from cd-player has some awfull trace damage from leaking capactor(s) (see picture).
        Is this salvagable and what would be the best way to restore the traces except for jumper wires?...
        02-25-2022, 12:43 PM
      • alegatorul
        sony bravia kdl-43w756c, no power, no sound
        by alegatorul
        the charger brick has 19,2-19,3 vcc
        changed the inverter board same result.
        where should i start?
        cheers
        11-15-2025, 10:00 AM
      • iglitare
        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
        by iglitare
        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
        Backlight seems to work, Sound (Setup menu after reset) works.
        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
        With my small knowledge i would think at least the cables are good.
        Can this happen because of a bad tcon board?
        Or is it always a bad/shorted...
        09-04-2025, 07:13 AM
        HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
        This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-12-2024, 03:36 PM
