Denon AVR687 with Sam Young Caps
  • Rob
    • Oct 2005
    • 47
    This is a 7.1 Home audio receiver. I bought it about 2 months ago at Circuit City and got a 3 year replacement Plan. I looked at the unit and I cannot find a cap that is not Sam Young . It was an open box and it was already a year old before I bought it. All the caps look good, and I stress this receiver pretty hard, it does get hot too.
    Any advise or input would be appreciated.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Denon AVR687 with Sam Young Caps
    Recap all large electrolytics with Panasonic FC or Rubycon ZL. If there are small electrolytics in the signal path, recap with Elna Cerafine/Silmic/Starget; Panasonic FC/NHG; Rubycon BlackGate NX (non-polar); or Nichicon Muse.
    • Cornito
      Denon AVR-2700H audio stops while receiver still works
      by Cornito
      Hello team,
      I've got a new issue with a Denon Avr-2700H.
      After several minutes working, receiver stops playing sound with a poc eared in the speakers.
      Receiver still work and display video with error message on display.
      Seems to me that is the main output relay.
      I'm looking for the service manual that I can't find for the moment.
      Does somebody have it?
      Regards...
      08-03-2025, 06:10 AM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • basskilla
      Denon PMA 350SE receiver missing part,need help for rewiring.
      by basskilla
      Hi Friends!
      I have a Denon PMA 350SE receiver,the remote controller-sensor pcb panel is missing from inside and without this it not even powering on by the main switch.
      So there are two connector left one 8 pin and one 3 pin.
      Would be Someone so kind and tell me which pin should connet to where,to make it work?
      I attached the service manual and pictures from the connectors.
      Thank You for the answer,and best wishes!...
      08-14-2023, 02:59 AM
      by momaka
      03-15-2023, 10:17 PM
