Samsung Soundbar HT-E8200
  • maxwell2121
    • Feb 2014
    • 10
    Help required with this soundbar which will not connect to sub woofer or the internet. Woofer blue link light comes on then goes to standby.
  • maxwell2121
    • Feb 2014
    • 10
    Re: Samsung Soundbar HT-E8200
    Solved. The sound o/p IC had blown apart. Replacement fitted, all now fine.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Cool, have you and image and part number to help others ?
        09-07-2024, 05:50 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
        09-06-2024, 11:40 PM
