Denon avr 2802 with no sound on speaker
  • klementor
    • Oct 2023
    • Russia
    #141
    Re: Denon avr 2802 with no sound on speaker
    Hi guys. First of all, I express my gratitude to everyone for this information. I also repaired my Denon AVR-2802. I changed only Flash: Atmel AT49LV002-70TC. The DSP is working fine. I took the firmware here on the forum. I ordered memory chips on Aliexpress. I ordered 3 pieces. Two were faulty and were used. Link to the seller https://aliexpress.ru/item/100500211...00018803732901
    • fox_tango
      • Dec 2023
      I found this thread and it describes my symptoms exactly. I located the DSP chips on e-bay and just got done replacing it. I put a "surgical drape" of aluminum foil and capton tape around the DSP and used my hot air gun to remove the old chip from the board. I thought about cutting the legs one at a time then cleaning up the mess with my soldering iron, but am happy that I tried the hot air first. It came off quickly with no issues. I did remove the tall electrolytic caps from the area first to get rid of obstacles.
Name:	ABLVV85p8djkOODpinjiJMPf5Hb09MFK_8iDes4dd0rAx2OipDT02bHkVy6ZYxq5f8DBUtyJKcM-o8VgoM7g8c2-W8OSMXdO9seFqVoYeZlI1-PBTAhO4lBij72HVHG-yAHnIrrRF0dNW7swTArr1NxY6n3MJoGEZ9nhaTSIJqGg-GN_B-HyJDYP4pFaLgO0Y3HUWRbPxOq8ZuDIpU49GHK09JcI52eHj_CM6LJCzECZYR9Ivut9FvFRM0320xS
ID:	3166772 Click image for larger version
Name:	ABLVV85wbuegbTBjxzyWRMiYpQyvyM7H-ll3YME3DFCSl7C_9V7eqpHk7GINbkYrdzjV4P9db7A_qAiKlyacCU7tVZwWWQKhFyzRVnyZ0a3hLof_zjyWiwDPu4WgnkS1hsmN0D0zRG00OtUjN6CW93ADLXOwcK_drlBN7d351OJ5ejsUoZrv4lg8scmFUOZwOWFP2Orc0UWkTSDCtB8hUkNXMs2dY3ot6fkhh1CeAeRIPFbr0lL72LhIu0gZDOj
      New chip installed:
Name:	ABLVV852oZW4udYbOHZC4GbGQFHiT9sZ-1gEIwnuvBUokDTCSxbINheoS4bXDmeMFLE19QFXMdqth9LVjon9zIs_a2A8ZDGTV1k1_jwKavxk8VVwSthQMaazoy0_g6W_kQcIQzTL8OygkYKdqH8LO_S6-37JlmQWgxDBwNYJMQ_sM0nkkKDazv21JZNAAaISsFLY2Auq7AIK6cg-lWSGqy05aAoVx6Vej75cpWPW8QakY1xTRsX_x6Y743tDCnS
      Unfortunately, my symptoms remain.
      I've reviewed the previous posts here and am not able to locate the flash ROM data contents file. I think this is my next step. I'm not sure if the previous posters are following this thread anymore, but I'd like to request help obtaining the flash file, as well as any leads on the flash memory device. I've come this far, I really want to try to get this unit back up and running.
      Thanks all for reading and for any advice you can offer.
      • azchris
        • 16
        Hi, Fox Tango. Glad to hear you are making some progress with your Denon.
        Please see my reply on 2-10-2018 where I posted pretty much everything you should need including the ROM file for the Flash IC.
        The ROM hex file still seems to be available for download; it's in the zip file attached to that posting.
        As I said in that post, I used a Macronix MX29LV040CTI-70G (4Mbit 512k x 8) FLASH IC and Digikey still has it in stock (see my post for the link
        https://www.digikey.com/en/products/...TI-70G/2744774
        Of course, the FLASH IC comes blank so it needs to be programmed. I still have my programmer and I can program the FLASH IC with the hex file
        but I don't currently have any more of the macronix chips on hand.
        Chris/azchris
        • fox_tango
          • Dec 2023
          Success!! It was my flash chip! As I mentioned previously, I swapped out the DSP chip and my symptoms stayed exactly the same. So, I replaced the flash IC and I have a perfectly working Denon 982 again! I'm am so grateful for everyone who contributed to this thread and provided the information. A special thanks goes out to azchris! I ordered the required flash chip from Digikey and azchris agreed to program it for me.
          To make the repair, I used mostly the same procedure as before. I made a heat resistance surgical drape from kapton tape and foil. I used my heat gun to heat the flash chip until the solder went molten, and picked it off with tweezers. Then cleaned the pads with solder wick and denatured alcohol. Finally, I soldered the flash IC back on by hand with a fine tip soldering iron. I did manage to create a few bridges on the fine pitch leads, but cleaned it off with the solder braid and all was well.
          To recap my symptoms, it was very faint audio, only audible with volume maxed out, and then if any input source was changed, audio was completely dead. Fix was replacing the DSP and flash IC.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5084
            • New Zealand
            #145
            Nice fix!
            Make sure you have a copy of that EEPROM data in case you need to reprogram it again!
            -David VanHorn
            • saviabr
              • Jan 2024
              • Israel
              #146
              I am a small French hacker, sorry for the translation ...
              The idea for me was to repair my DENON AVR-2802 without buying a memory or programmer
              Hi, friend! I liked your idea. I also have an Arduino mega 2560 lying in my closet unused.
              Could you send me a diagram of your Arduino programmer and W29C020 memory connections.
              This would help me a lot. Thank you!​
              • Robert85
                #147
                Hello, I also have this problem with a Denon AVR2802 related to the sound, I downloaded the bin posted on the forum but I can't write it along the way, an error appears, am I not doing something right or is there something else, I used the AT49LV002 as the one in the device, I tried several pieces but without results, I use TL866 for programming.
                • Robert85
                  #148
                  Greetings again, I see that there are not many new posts on this issue, but I'm back with news, I managed to bring back to life 2 such devices with the ideas from this forum, everything boils down to the quality of the parts, by buying quality parts I managed to program the flash,
                  • Astaloki
                    • Jan 2025
                    #149
                    I found my Denon AVR2802 had failed in the way described above. However I noticed that in some situations (detailed below) I could hear very faint audio coming through the amp.
                    If you would like to re-use the following functionality of your amp then there is a fairly easy fix. With the ‘fixed' unit I can:
                    •Use the amplifier to amplify an external (analogue) source
                    •Volume control works
                    •Muting works
                    •Power speakers A and or B, and potentially surround and sub as separate channels (have not tested)
                    What does not work:
                    •The radio receiver
                    •Switching to any other sources
                    •Video switching (untested)
                    Step 1 - confirm your amp has the same fault symptoms as mine had:
                    A.Connect a source to the FL/FR EXT. IN inputs (e.g. phone, MP3 player, computer) [img]
                    B.Connect speakers to the FR/FL outputs
                    C.Configure the ‘source' to be EXT.IN
                    D.Turn up the volume to around 0dB - you should hear nothing.
                    E.Turn off the amp and turn it back on
                    F.Only adjust the main volume, turning it gradually up to +18db - you should hear the EXT.IN source signal coming faintly out the speakers.
                    G.Note if you do any other adjustment to sources at this point then you will have to power-cycle the system.
                    Step 2 - disable the mute which is in place
                    There are a couple of places in the audio signal path that the system can mute the sound. Some are electronic and some are electromechanical (i.e. relays). I think what was happening on my system was that because the main DSP was failing (probably due to the ROM failing as described elsewhere) the microcontroller was then muting the signal. The electronic mute used is not infinite, hence why the test in step 1 works. In this step we disable the mute (permanently).
                    A.Power off the amp
                    B.Take off the top case (as described in the service manual)
                    C.Unscrew the back panel (a lot of screws!)
                    D.Remove the DSP card to give access to connecter CX114 on the base PCB. [img]
                    E.Use a solder blob to short pins 3 and 4 of this connector. [img]
                    Step 3 - test
                    A.Re-attach “EXT.IN” inputs to test and feed in a signal
                    B.Power on the amp and slowly increase main volume from lowest volume.
                    C.If this fix has been successful then you will hear sound from your speakers when the main volume is much lower that in step 1.
                    D.Having confirmed the fix, reassemble the unit (you could run it permanently without the failed DSP board).
                    E.Enjoy a few more years out of your amp instead of dumping it!
                    Note: even with this fix any change to the ‘source' will cause the amp to mute until it is power cycled. This functionality works for me (I only use one internet-connected source into my amp) but may not work for you. No DSP or digital functions (like DTS, Dolby, etc) are available. If you need the DSP then consider replacing the ROM as detailed elsewhere.
                    The above steps worked for me and my Denon avr-2802 is making sounds once again.
                    Thanks so much to dbdenon for his time and effort in creating this work around.
                    • FuzzyOwl
                      Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
                      by FuzzyOwl
                      Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
                      Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
                      Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
                      I've followed the trouble shooting guide, audio check...
                      12-05-2024, 11:54 AM
                    • benspawn02
                      Anthem MRX500 - no sound. R2A15218FP issue??
                      by benspawn02
                      Dear Electronics Experts:
                      I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                      08-12-2023, 04:46 AM
                    • cazi1001
                      Samsung Galaxy A22 - strange problem with sound / speaker
                      by cazi1001
                      I have a Samsung Galaxy A22 5G with a strange error image.
                      If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
                      If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
                      If I listen music via Youtube, even the upper or lower speaker don't work.
                      If I switch louder or quieter, the sign on the screen show me a headphone.
                      If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
                      Does anyone have any ideas, what the problem could be?​
                      02-10-2024, 09:16 AM
                    • Gumboil
                      Denon AVR-X2000 no sound
                      by Gumboil
                      Good day all
                      My first post on the forum, tried to find a introduction page, but couldnt. So thank you for having me here.
                      After spending most of the past 2 days Googling and watching Youtube videos, I came across the forum, in the hopes that I could get some assistance with the above mentioned amplifier. As I do most days, I switched the unit on yesterday morning, got the relay clicks as per normal, but no sound from any of the speakers. Tried "Audio Direct' and the same issues there. In a panic state, I did a factory reset, without any luck. Then disconnected all...
                      06-08-2025, 02:43 PM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
