McIntosh MS300 Music server motherboard caps
  • Cohibaman
    • Jan 2015
    • 66
    Re: Music server motherboard caps
    Thanks! That's what I figured, especially since this thing draws so little (1,100mA @3.3V; 1,250mA @ 5V, and 550mA @ 12V). Start-up is a whole 51 Watts for about a second!
    • Cohibaman
      • Jan 2015
      • 66
      Can anyone identify fuses FB2 and FB4 and what I can replace them with (besides a solder bridge lol)? These things are ridiculously small, no markings, and FB2 is open.
        • 31039
        those are inductors.
        • Cohibaman
          • Jan 2015
          • 66
          Ahhhh FB = ferrite bead?
            • 31039
            right
            • Cohibaman
              • Jan 2015
              • 66
              How do I determine the value of the bad one?
                • 31039
                throw some dice?
                you cant - if you can meter inductance then read the good ones.
                or just find one the same size on some junk - it's probably not critical get be exact.
                • Cohibaman
                  • Jan 2015
                  • 66
                  Yup, I already harvested a slightly larger one from a cable TV box MB. It's working great. The old one burned out while I was troubleshooting the video output, so no worries with this one burning up. I did learn my soldering iron tip isn't isolated though! Lol
                  • Cohibaman
                    • Jan 2015
                    • 66
                    Btw, thanks stj!
                      • 31039
                      a good tip, your soldering iron tip is connected to ground, cut the wire in the handle or base and put a 1meg resistor inline.
                      that will disipate static but not pass enough current for a fireworks display if you solder something that is still powered.
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • Bonaventure Vigil
                        Variable DC Power Supply cannot boot motherboard
                        by Bonaventure Vigil
                        Hi there,
                        Guys anyone here can help me. During troubleshoot the motherboard, my 1st and new psu unable to boot the motherboard. Even though i set the 20V, my old Compaq CQ42 motherboard had the led white light at charging port. When press on button, the led blinking to red and gone back to white state. But i change the oem hp compaq adapter which is i measure 19.45V. Using that can boot the motherboard and fan spinning. Then i reconnect psu and tried set the 19.45V, still blinking red. Anyone know what happen? Is it psu not compatible? All is check and voltage is there....
                        10-17-2024, 12:16 AM
