Sansui XR-Q9 turntable issue
  • tech2014
    • Aug 2014
    • 807
    The tonearm does not move when pressing the up/down button. It is my grandmothers record player. Anyone ever work on one before?
  • Soma89
    Numark TT500 Turntable...weird power "freezing" issue
    by Soma89
    Hello there,
    I have a TT500 dj turntable that sometimes "freezes" upon powering on. This means that it lights up as normal, but does not react when pressing the play button (to turn the platter) or adjusting any settings through the push buttons or even move the slider/fader control; it just freezes in place with its default settings.
    To get the turntable working normally again, I simply power off and on the turntable again and it usually boots up normally the second or third time around.
    The manufacturer is unable to provide me with a service manual....
    05-31-2022, 10:47 PM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    🛠 Original Issue
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ugamazing
    by ugamazing
    12-17-2024, 07:05 PM
  • shahnld
    Lenovo legion 5 pro startup issue
    by shahnld
    Good day Experts
    I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
    A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
    And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
    08-24-2025, 12:31 PM
  • ahmarzo
    Acer laptop battery draining issue
    by ahmarzo
    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
    08-02-2025, 06:39 AM
