FenderFM212R reverb problem.
  • hs5424
    HS5424
    • Jun 2025
    • 13
    • Ireland
    Hi All,
    Anyone out there did any fault finding on the above amp with no reverb. I suspect the spring reverb tank is faulty but want confirmation before ordering a new one. Scoped that audio is present at the i/p to the tank (sinewave gets distorted when the tank is connected). I also injected a tone on the o/p of the tank which I can hear on the amps speaker.
    Any advice appreciated.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    could very well be that there is something wrong with the spring tank. I worked on a few of these, but never had a problem with the spring tank itself. you see anything on the output of the spring tank?
    • hs5424
      HS5424
      • Jun 2025
      • 13
      • Ireland
      Hi Capleaker,
      Thanks for your reply and schematic.
      I have a schematic and went through the normal process of signal tracing. I replaced U4 and U5 as I thought this would be a quick and cheap fix as these handle the i/p ond o/p of the tank reverb. I injected a tone on the o/p tank socket and this gets through to the speaker ok. I tried injecting a tone (experiment) on the tanks i/p but nothing appears at the other side. The i/p and o/p on these tanks have different impedances so I realise that my test may not be very scientific or conclusive. I found some DC resistance figures for the tank online which shows the i/p dc should read 36 ohms. It check out to be 66 ohms. The o/p should be 200 ohms, it checks out to be 176 ohms. I am suspect that the i/p side of the tank is the culprit so I have ordered a new one. What is really puzzling me is if I physically shake the tank I cannot hear the normal 'broken glass' sound at the speaker. Scoping the tanks o/p disconnected shows an AC signal.
      I will update when the replacement arrives. Fingers crossed.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        Hm… did you open that spring tank up yet? If not, open it. I wonder if there is a wire that came undone.
        • hs5424
          HS5424
          • Jun 2025
          • 13
          • Ireland
          First thing I checked.
          Both ends are closed circuit which I measured on the rca sockets.
          • hs5424
            HS5424
            • Jun 2025
            • 13
            • Ireland
            UPDATE.
            New tank arrived and fitted but alas still no reverb so I had a look at the o/p side and found that the reverb pot was 50k and not 250k, so a man made fault. Now working.
            For the life of me I cannot tell the difference in sound reverb no matter what way I connect the tank. The original unit has a red RCA on the side marked IN, whereas the new one has a red RCA marked as out. The original ones markings are obvious as the red RCA has signal coming from the preamp stages so I would call it i/p also.
            Puzzling.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              Weird. So the amp works, The output and input of the reverb circuit works, installed a new tank, but still no reverb / echo sound? Did somebody maybe mod this speaker, or there is something broken in the reverb circuit.
              • hs5424
                HS5424
                • Jun 2025
                • 13
                • Ireland
                To clarify.
                I had replaced the reverb potentiometer but it was marked with the incorrect value. Replaced with the correct value and reverb worked again. I also tried the original tank which is working also. It doesn't seem to make any difference which way the new tank is installed, ie in/out rca plugs.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  Ahh! Got it now! At least you got her going again. These pots inside these amps are problematic. The thin waver cracks inside and then same problem, or the -16V is gone. Good job!
                  • hs5424
                    HS5424
                    • Jun 2025
                    • 13
                    • Ireland
                    I found it difficult to source fender pots at a reasonable price for theses amps so I bought a load of different values from China. If you remove the mounting legs from the original pots and with a little bit of basic engineering you can fit the legs to the new pots. Job done for little money.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8352
                      I found matching ones on Ali. Works fine as kind.
                      • mon2
                        • 14880
                        Hey! Have one of these in the shop now. We are servicing more and more audio equipment locally in our city. As a FYI, you can purchase the replacement stereo and mono PCB mount jacks from Farnell (aka Avnet). Just replaced each of the 20 year old plastic worn out ones yesterday with the more rugged metal versions of the same. Drop in replacements from Amphenol.
                        Sharing the part #s for future readers:
                        ACJS-MHDRM
                        AMPHENOL AUDIO ACJS-MHDRM Phone Audio Connector, 3 Contacts, Jack, Panel Mount, Tin Plated Contacts
                        * this is with 6 contacts total (2 x 3) = stereo - there are 3 of these connectors on the 212R
                        ACJM-MHDRM
                        AMPHENOL AUDIO ACJM-MHDRM Phone Audio Connector, 1/4" Mono, R/A, 2 Contacts, Receptacle, Panel PCB Mount
                        * this is with 4 contacts total (2x2) = mono - there are 2 of these connectors on the 212R
                        Our unit in for repair was manhandled by other techs and the pots are with the wrong values. About to replace with Bourns pots (mix of log and linear style must be used). The Bourns do not offer the hind legs for the support but have to be better than the way too loose pots onboard.
                        Bourns we are sourcing from Digikey. Will update this thread after the repair.
                          MSI Gaming GP62 8RD-052XRU World of Tanks Notebook GP Specification for Upgrade or Repair
                          This specification for the MSI Gaming GP62 8RD-052XRU World of Tanks Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP62 8RD-052XRU World of Tanks boardview and GP62 8RD-052XRU World of Tanks schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 05:00 PM
                          MSI Gaming GP62 8RD-050RU World of Tanks Notebook GP Specification for Upgrade or Repair
                          This specification for the MSI Gaming GP62 8RD-050RU World of Tanks Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP62 8RD-050RU World of Tanks boardview and GP62 8RD-050RU World of Tanks schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 08:40 AM
                        • redwire
                          Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
                          by redwire
                          My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
                          Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
                          Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
                          The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
                          The tone caps are green film caps I left alone. Newer...
                          07-30-2023, 08:21 PM
                        • ChaosLegionnaire
                          correct way to connect bare speaker wires into spring clip terminals?
                          by ChaosLegionnaire
                          i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
                          however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
                          i googled...
                          10-27-2022, 06:19 AM
                        • hakuuart
                          Error E4 of HP Smart Tank 750 printer
                          by hakuuart
                          Hello everyone, I need some help or advice regarding the HP Smart Tank 750 device. I have already checked for paper jams and anything stuck inside, as well as all the flex cables, but I still encounter an E4 error. We have taken it to customer service for inspection, but they don't know how to fix it. Is it possible that the issue lies with the main board or the sensor? I would really appreciate any guidance from those who have experienced this problem. Thank you!...
                          05-12-2025, 08:51 AM
