TEA2025B Date Markings - no info
  • chozo4
    Nothing Special
    • 134
    There has been one thing about the TEA2025B Operational Amplifier that I cannot seem to find information on. The ones manufactured by ST usually are marked by the Model#, then the date code or batch code(?), followed by the country of manufacture.
    The part I don't understand exactly is the date code format.
    I have several from different sources in front of me right now, all Manufactured in Malaysia but with the following codes:
    Code:
    W990D0001 (PCI Yamaha)
    W991W9841(PCI Yamaha)
    W991E9422 (PCI Yamaha)
    W993U9648 (ISA soundblaster)
    ????N9440 (ISA soundblaster)
    ????69819 (PCI Yamaha)
    At first I thought the first set were to indicate from 1990-1993 but the 93's were on the soundblasters.. and the others on newer PCI soundcards. I'm assuming now that I compare the date stamps altogether the last 4 digits indicate the year/week I just realized. The parts I don't know of though are the first 5 digits and mostly interested in digit 4 and 5 respectively.
    The last two I only have partial codes from as they were shorted IC's with a massive hole literally blown clean out from the top of it. Pictures on request for laughs
    Even crap caps can be useful... such as blank rounds for prop gunfights.
  • sanalelevenstar
    Yamaha RX-V485 Wn9711 Update
    by sanalelevenstar
    Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
    I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
    I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
    12-04-2024, 04:32 AM
  • sanalelevenstar
    Yamaha RX-V485 receiver. After encountering a "version error"
    by sanalelevenstar
    I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
    After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
    I managed to find the service...
    09-10-2025, 01:54 AM
  • jjne
    Yamaha RX V675 sound issues
    by jjne
    I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
    From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
    At first I thought it was either a speaker relay or the DSP, but I don't think...
    06-24-2025, 07:01 AM
  • AlexVG
    YAMAHA CLP-550 without of sound
    by AlexVG
    Hi.
    I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
    I have replaced all green marked elements, but it gave me nothing.
    The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
    But it is custom YAMAHA's chip, and I can't find any information about it.
    Maybe somebody came across with the same issue?
    Any information will be very useful. I will be very appreciated.
    Thank you....
    06-08-2025, 09:29 AM
  • hemant_2222
    Yamaha RX-A1020 full dead
    by hemant_2222
    Hello Everyone,
    Greetings!
    It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
    09-14-2024, 11:25 AM
