Jamo A-101 Sub Amp
  • nissam72
    • Jan 2015
    • 7
    • India
    Re: Jamo A-101 Sub Amp
    Good morning Dear,
    Finally after a long time I have removed glues from the PCB, but still having same problem, is it possible to replace PWM IC?
    Kind Regards,
    Nissam.
      So can you read the P/N as printed for that Gate driver IC U2?
      • nissam72
        • Jan 2015
        • 7
        • India
        There is no number..
        • Agent24
          I see dead caps
          • Oct 2007
          • 4953
          • New Zealand
          Don't you just love it when they do that?
          If you can draw up a schematic of what pins of the IC connect to what, maybe someone can figure out what it might be. They're probably using a fairly well-known part.
          -David VanHorn
          • rievax_60
            • May 2012
            • 897
            • australia
            Originally posted by japlytic
            I have handled a Jamo SUB250 unit and it has a variation of an "old school" computer power supply circuit (self oscillating) - the A-101 should be of the same variant mentioned thereof.
            I just opened up a Jamo SUB250 also. I can confirm that the SMPS really is a self oscillating half bridge using a pair of IRF730 MOSFETs which were shorted.
            I sent Jamo a message via their Facebook page expressing my annoyance that their products are failing prematurely because of the yellow glue.
            • rievax_60
              • May 2012
              • 897
              • australia
              #26
              Originally posted by nissam72
              Good morning Dear,
              Kind Regards,
              Nissam.
              U2 looks like it has built in high/low side drive. It might be a type of control IC that is normally found in something like the inverter in a CCFL lamp.
              • rievax_60
                • May 2012
                • 897
                • australia
                #27
                This looks right, https://cdn.badcaps-static.com/pdfs/...345f70bf55.pdf
                • Huub88
                  • May 2017
                  • Netherlands
                  #28
                  I'm new to this forum and I registered because of this thread. I have a jamo a101 sub that stopped working overnight. The standby circuit is powered as far as I can tell, it just won't switch on when I apply an audio signal. How is the sub amp supposed to come out of standby?
                  Thank in advance
                  • sreeraj m
                    • Jul 2018
                    • india
                    #29
                    I have a jamo a101 sub that stopped working.i need to know the MOSFETs details in frond of the 100V 470 uf cap side
                      What is the P/N as printed on the body?
                      • tothta75
                        • Oct 2020
                        • Hungary
                        #31
                        Halo,
                        could anyone tell me please, what should I use to remove the discoloured glue?
                        (I am a REAL beginner in electronics. Never repaired anything :-) )
                        THX:
                        Tamás
                        • jesgatt
                          • Jan 2021
                          • Malta
                          #32
                          Originally posted by rievax_60
                          Hi, I know that this post is a bit old, but is this the part number for the PWM controller? I tried IR21531D (which is quite similar) but the IC seems to not provide any oscillations (Note: I changed the IRF740 to P10NK60, since they were shorted).
                          • Jicisson
                            • Jul 2022
                            • France
                            #33
                            Bonjour,
                            Je suis dans le cas #2 ou les traces de coulures sont sur ma pcb. Il y a des traces de surchauffe au niveau des transistors, comme sur la photo.
                            Est-il possible d'avoir les valeurs des condensateurs et des transistors concernés ?
                            Merci de votre aide.
                            Jicisson
                            • Tannie
                              • Mar 2024
                              • Nederland
                              #34
                              Today I recieved a Jamo A101 subwoofer.
                              The problem was it did not work at all. The switched power supply did not start oscillating. After measuring I noticed the feedback optocoupler was not switching. After checking some caps I finally found a defective Schottky diode. This one was fully shorted.
                              See backside of PCB here below. I have marked de culpritt diode in red. It is a SS16 diode. After replacing it, the subwoofer works well again.
