Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
  • waigy
    • Nov 2009
    • 93
    One step forward two steps back.
    I excitedly built it all back up, connected the speaker wires etc. into the car then drove about a mile to the nearest place I can turn up the volume without people hearing and it's much worse.
    There's now something very wrong with the rear gain pot.
    Just before soldering it back onto the board I measured the resistance and it was still working smoothly from zero up to 20.
    But now, even with the rear rca inputs disconnected, if I turn the rear gain pot a tiny bit, the rear speakers crackle and start to move in and out.
    With the rear right connected, it distorts much worse than it did before.
    I can manage to get the rear left working quietly, but there's something wrong there too.
    With the pot at minimum it also starts crackling and cutting in and out, but when I get up to halfway, it quietens down and starts from a low level then keeps getting louder till the maximum setting.
    I'm at the point of giving up here.
    I've already spent loads of time on this and it's an amp that's only worth a few quid when working properly.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8351
      Either replace the pot or for sanity sake's put in a fixed resistor instead. That's why a oscilloscope is a must to make a project like this "easy work" out of it.
      • waigy
        • Nov 2009
        • 93
        I found out the cause of all the crazy stuff the amp was doing.
        After checking the resistance of the pot, but just before soldering it back into the board, I used pliers to make sure the metal tabs that hold the pot together were bent firmly back into position.
        When I did that, I put a fine crack in the back plate of the pot.
        I just checked the resistance again and it was going up to 200 then getting no reading.
        Because I bought two car amps last night for £20, I'm past the point of considering this junk now so I just put one of the 100k pots for adjusting the high pass frequency in place of the rear gain.
        I'll make sure I only turn it a small amount from minimum as it quickly gets up to 20k.
        I'll give it one more chance and, if there's still any distortion in the right rear, it's time for a float test.
        Throw it in my nearest river and see if it floats.
        • redwire
          • Dec 2010
          • 3912
          You can get a replacement pot instead of abandoning it. How many times can you tell a girl you've got a Clarion in the bedroom lol.
          • waigy
            • Nov 2009
            • 93
            I tried the 100k pot and it still did the exact same thing making the speakers pulse slowly in and out and crackling etc., that was before even starting to turn the pot up, so it will be something else I have damaged on the board by taking it in and out a few times.
            I had a couple of schoolboy errors when refitting the large heatsinks and saw sparks twice so that might have blown something else.
            I just got myself another amp to add to the two I got last night (one of which was dead on arrival).
            So I currently own 5 amps, with 2 not working, but the amps that are working are much better than the amp I've been trying to save so tomorrow I will be fitting them in the car.
            I'm going to keep the dead amps for spare components, or float tests.
            Thanks for all the help everyone.
            • MrCommunistGen
              Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
              by MrCommunistGen
              My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
              I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
              07-12-2021, 05:11 PM
            • jinu_j
              How to test Subwoofer Amplifier with only a multimeter
              by jinu_j
              Hi Folks
              Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
              Problem
              I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
              Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
              Any advice would be appreciated...
              08-29-2024, 02:05 AM
            • UserXP
              Mackie CR4 amplifier no sound
              by UserXP
              Hi, people.
              I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
              Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
              10-17-2020, 05:06 PM
            • Coert van Dorsten
              Sansui Integrated Amplifier replacement volume control troubles
              by Coert van Dorsten
              Hi all you clever electronmic gooroos!
              I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
              10-15-2025, 02:54 PM
            • mikey5791
              Help on car amplifier only one channel works
              by mikey5791
              Hi all forum members,
              Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
              My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
              08-06-2025, 10:36 PM
