Lanzar Optidrive 400id amplifier going into protect
  • Op4500
    • Oct 2013
    • 29
    I'm going to work on a busted amplifier for a friend, it's a Lanzar optidrive 4001D, protect lights up and it sends a low frequency on/off pulse to the subwoofer and that's all it does. I haven't tested it yet, but I'm wondering if anyone has documentation on it. I'm going to start by testing the 24 MOSFETS. The board has no visible burn marks or signs of stress, capacitors all appear normal and aren't a brand I typically see fail. I'm told this amp is only a year old and he said it's 4000w RMS. This thing is beefy as hell, never worked on anything with such a ridiculous bank of filter caps, it has 6 3300uF 100v capacitors, 24 35v 2200uF capacitors, connectors sized for 0 guage wire. This thing is a BEAST. Just looking for any helpful advice, I've worked on a lot of power supplies, a couple home amps and digital circuits but this is my first car amp.
    Heres a link to a photo gallery,
    • 31218
    Re: Lanzar Optidrive 400id amplifier going into protect
    the wattage is BS, it's probably no more than 400w sine.
    those pinochio numbers are always used on car audio!
    you have 2 parts to that unit.
    the first part is a split invertor.
    it steps the 12v upto probably about 30-60v in a 60-0-60 style output.
    the second part is the actual amplifier.
    start by checking the fets for shorts.
    they are probably wired in parallel to a degree, so if you find a few that look shorted, remove them or lift one of the legs one at a time & re-test.
    these type of repairs are easy, but slow.
    • Op4500
      • Oct 2013
      • 29
      It definitely has some bad FETs, tested 4 so far and 2 were shorted between all 3 pins. I posted a thread in the soldering board about it but I'm having a really hard time getting these MOSFETs out, using a 40w soldering iron and copper braid to remove them. Is there a better technique to do this? I broke the leads off one of them because I pretty much have to heat up each pin one at a time and pry it out very carefully. I have to remove all of them because each bank of 6 is in parallel from what I can tell, they all read as being shorted when in the circuit.
        • 31218
        a pump is better than braid, because your probably getting the braid stuck as the solder cools.
        a bigger iron tip would help
        • Op4500
          • Oct 2013
          • 29
          I got one of those little solder sucker bulbs from radioshack, it doesn't really work. Maybe one of those syringe type ones would be better.
          • MrCommunistGen
            Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
            by MrCommunistGen
            My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
            I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
            07-12-2021, 05:11 PM
          • jinu_j
            How to test Subwoofer Amplifier with only a multimeter
            by jinu_j
            Hi Folks
            Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
            Problem
            I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
            Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
            Any advice would be appreciated...
            08-29-2024, 02:05 AM
          • UserXP
            Mackie CR4 amplifier no sound
            by UserXP
            Hi, people.
            I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
            Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
            10-17-2020, 05:06 PM
          • Coert van Dorsten
            Sansui Integrated Amplifier replacement volume control troubles
            by Coert van Dorsten
            Hi all you clever electronmic gooroos!
            I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
            Today, 02:54 PM
          • mikey5791
            Help on car amplifier only one channel works
            by mikey5791
            Hi all forum members,
            Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
            My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
            08-06-2025, 10:36 PM
