Pioneer sg530
  • Evets
    • May 2024
    • 28
    Pioneer sg530
    This forum has been so useful to me and I thank all the people who have helped me in the past.
    I'm now in need of some more assistance, I have purchased a Pioneer sg530 graphic equaliser to add to my Pioneer X-G7 hifi system. This equaliser was a factory option on this system but as this was purchased second hand I didn't get a user manual. Searching the internet has been fruitless, can anyone help with a schematic of how this should be wired into the system or possible a copy of the user manual.
  • R_J
    • 9579
    type this into GOOGLE "Pioneer sg 530 manual"
    • Evets
      • May 2024
      • 28
      Thanks, that was the first thing I did and although a couple of sites had the service manual which I did download. This however this did not contain any connection information. A couple of sites claimed to have the user manual but the links either failed to download or open correctly and I ignored any that were not in English ( I could have been downloading anything). I don't give up easily and tried several search engines. Pioneer no longer provide information on these older models. If you can find a connection schematic and provide a working link I would be grateful.
      • R_J
        • 9579
        There is an owners manual for a SG-540 which may be very close, or maybe someone with a hifiengine account can download it
        It is a equalizer, not that hard to install.
        • Evets
          • May 2024
          • 28
          I tried registering for a hifi engine account but they aren't accepting new accounts. I'm new to electronics so 'easy' is relative to knowledge. In my day job rebuilding complex mechanical machines is relatively easy.
          • R_J
            • 9579
            I know they are not accepting new members, maybe someone here has a membership and can download the owner's manual.
            Did you look at the manual for the sg-540? Many amps have a pair of metal loops for the preamp section that you remove to insert a eq in the audio path.
            • Evets
              • May 2024
              • 28
              Yes I have downloaded the manual for the sg540 but not had time to look at, later tonight maybe. Unfortunately my amp doesn't have the pressure amp loops which raises another question. Do I need to hard wire the EQ into the amp or use a separate EQ for each peripheral?
              • Evets
                • May 2024
                • 28
                Pre amp not pressure amp... I hate predictive text.
                • R_J
                  • 9579
                  If you have the sa-930 amp you can connect the eq to the TAPE 2/ADAPTOR rec and play jacks then switch the TAPE2/ADAPTOR switch to ON
                  Connect it just like it is connected in the SG-540 mannual
                  • Evets
                    • May 2024
                    • 28
                    • ccbargains
                      Pioneer SX-S30 need help identifying SMD semiconductors Also need service manual and/or schematic
                      by ccbargains
                      I have not been able to locate a service manual for this Pioneer SX-S30 receiver. The unit will not turn on. I am troubleshooting the switch mode power supply. I found three smd semiconductors that test open while in circuit. The first (Q904) is a transistor marked AZ43W. The second is a diode D905 marked L68 and the last is a diode D906 marked 66 CU1M. I have attached photos.
                      Any help would be appreciated. Thank you....
                      06-30-2024, 11:55 AM
                    • EduCabral
                      [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                      by EduCabral
                      I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                      While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                      🔧 Details:
                      • Model: YT-M06
                      • Interface: Pioneer 1
                      • MCU: Fujitsu MB89F202
                      • Goal: Find a valid .bin firmware file or memory dump from a working unit
                      I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                      07-15-2025, 12:26 AM
                    • I8jjrnhh4thvtl0dWZoY
                      Repair Manual for Bosch SHX55M05UC/46 Dishwasher (702_58300000148618_ara_en_a)
                      by I8jjrnhh4thvtl0dWZoY
                      Repair manual part number 702_58300000148618_ara_en_a
                      It took way too much effort to find this manual so I am sharing it here so the next person can find it easily. Also, I am mad at Bosch for not publishing it on their website, so they deserve to have it leaked....
                      07-14-2025, 07:36 PM
                      Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                      Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                      various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                      Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                      trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                      what is wrong with your PC in just seconds. It saves you time and money.
                      Our new and improved design...
                      11-01-2024, 06:29 AM
                    • pixelcap
                      Pioneer Kuro Pro 111FD 8 red blink error
                      by pixelcap
                      Pioneer Kuro Pro 111FD 8 blink red LED.
                      I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                      So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                      based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                      10-06-2024, 11:26 PM
