BOSE soundlink color BIOS or Firmware request
  • XIII
    XIII
    • Mar 2024
    • 22
    • Tunisia
    i have this bose soundlink with no charging nor any sign of life, so after digging they told me that the issues is mainly with the firmware which is corrupted, I looked everywhere for a dumb with no luck, can anyone help me out ?
    PS: the chip is a 4mb chip, I found a dumb online but it has 16mb weirdly tho he had the same chip that I did but I don't know how he did it
    thank you in advance.
  • XIII
    XIII
    • Mar 2024
    • 22
    • Tunisia
    i did plug in the speaker to my laptop, it got detected and I could update the firmware, weirdly the device kept going on and off during that, then once it's done the speaker kept beeping once each time I plug it into the charger then it went back to where we started.
    • Steadily7-Colossal0
      bose soundlink color 2 strange behavior
      by Steadily7-Colossal0
      My dad gave me his bose soundlink color 2, claiming that the charging port was loose. I opened it up, plugged it in, probed around with a multimeter, and I can measure 5V all over the board. I wiggle the charging cable around, no change. The port looks fine: sturdy, clean contacts. I measure across the battery wires and I get 0V, so I assumed the battery was the problem. But then a few minutes later after I disconnected and re-connected the daughter board with the buttons, lights were flashing and I was reading 3.3V across the battery wires. The only logical explanation for this I could come up...
      12-12-2024, 03:20 PM
    • karlox
      bios BOSE |SOUNDLINK COLOR II
      by karlox
      good evening, does anyone by any chance have the bios of the BOSE speakers | SOUNDLINK COLOR II. The equipment is simply dead, I want to try a reprogramming of the chip before looking for an electronic fault. Thank you.
      02-22-2022, 07:32 PM
    • GodGecko
      Hacking the Bose Soundlink Color II
      by GodGecko
      So i have the said device which doesnt turn on and doeasnt take power because it has a battery fault.
      The battery has a Ship mode i tried turning that off but it doesnt do anything so i was wondering if the device can be hacked so it takes the power from the USB port directly....
      10-11-2022, 09:33 AM
    • Jagatha
      Bose SoundLink Color II Portable Bluetooth Speaker
      by Jagatha
      Hi
      My portable speaker, a Bose sound link color 2, all of a sudden stopped and has no life even if I try to charge it, no lights or any chimes. After taking it apart I realized that the battery is not putting out any voltage into the board.
      The battery management circuit is a sealed one and I'm trying to identify it. Could you help me to identify this part please? or a possible replacement for it?
      It looks like it is a Microchip product that states R700 108T on it. Could not find it online.
      09-02-2021, 09:36 PM
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
