BOSE soundlink color BIOS or Firmware request
  • XIII
    XIII
    • Mar 2024
    • 22
    • Tunisia
    i have this bose soundlink with no charging nor any sign of life, so after digging they told me that the issues is mainly with the firmware which is corrupted, I looked everywhere for a dumb with no luck, can anyone help me out ?
    PS: the chip is a 4mb chip, I found a dumb online but it has 16mb weirdly tho he had the same chip that I did but I don't know how he did it
    thank you in advance.
  • XIII
    XIII
    • Mar 2024
    • 22
    • Tunisia
    i did plug in the speaker to my laptop, it got detected and I could update the firmware, weirdly the device kept going on and off during that, then once it's done the speaker kept beeping once each time I plug it into the charger then it went back to where we started.
    • Steadily7-Colossal0
      bose soundlink color 2 strange behavior
      by Steadily7-Colossal0
      My dad gave me his bose soundlink color 2, claiming that the charging port was loose. I opened it up, plugged it in, probed around with a multimeter, and I can measure 5V all over the board. I wiggle the charging cable around, no change. The port looks fine: sturdy, clean contacts. I measure across the battery wires and I get 0V, so I assumed the battery was the problem. But then a few minutes later after I disconnected and re-connected the daughter board with the buttons, lights were flashing and I was reading 3.3V across the battery wires. The only logical explanation for this I could come up...
      12-12-2024, 03:20 PM
    • karlox
      bios BOSE |SOUNDLINK COLOR II
      by karlox
      good evening, does anyone by any chance have the bios of the BOSE speakers | SOUNDLINK COLOR II. The equipment is simply dead, I want to try a reprogramming of the chip before looking for an electronic fault. Thank you.
      02-22-2022, 07:32 PM
    • Jagatha
      Bose SoundLink Color II Portable Bluetooth Speaker
      by Jagatha
      Hi
      My portable speaker, a Bose sound link color 2, all of a sudden stopped and has no life even if I try to charge it, no lights or any chimes. After taking it apart I realized that the battery is not putting out any voltage into the board.
      The battery management circuit is a sealed one and I'm trying to identify it. Could you help me to identify this part please? or a possible replacement for it?
      It looks like it is a Microchip product that states R700 108T on it. Could not find it online.
      09-02-2021, 09:36 PM
    • GodGecko
      Hacking the Bose Soundlink Color II
      by GodGecko
      So i have the said device which doesnt turn on and doeasnt take power because it has a battery fault.
      The battery has a Ship mode i tried turning that off but it doesnt do anything so i was wondering if the device can be hacked so it takes the power from the USB port directly....
      10-11-2022, 09:33 AM
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
