Pioneer SX-S30 need help identifying SMD semiconductors Also need service manual and/or schematic
  • ccbargains
    • Jan 2017
    • 7
    • usa
    I have not been able to locate a service manual for this Pioneer SX-S30 receiver. The unit will not turn on. I am troubleshooting the switch mode power supply. I found three smd semiconductors that test open while in circuit. The first (Q904) is a transistor marked AZ43W. The second is a diode D905 marked L68 and the last is a diode D906 marked 66 CU1M. I have attached photos.
    Any help would be appreciated. Thank you.
  • R_J
    • 9587
    Are you measuring ANY voltages on the output pins of the power supply? Check if you have +12v standby on P902 (1~3) if not check fuse F902
    Q908 is the standby switching ic 2A153
    If you don't have 12v standby Q904 circuit will not turn on and operate
    Q904 is a INA5001API transistor, D905 is a M1FL20U
    D906 is a GU1M ultrafast 1000v, 1amp diode
    • ccbargains
      • Jan 2017
      • 7
      • usa
      Thank you very much for your help!
      I do have 5V and 12V but no 33V. The unit does not completely turn on. I do get a display over hdmi but the display on the unit does not light up.
      Any suggestions?
      • ccbargains
        • Jan 2017
        • 7
        • usa
        Also Q904, D905 and D906 did not register anything with my multimeter using diode check.
        • R_J
          • 9587
          Check P902 pin 7 for PON, this should be a high, likely around 3.3 vdc, this is needed to turn on the power supply +30v and the display supply
          section
          There are two other pins on that plug, 8 TSENS and 9 PSENS what are their voltages? TSENS could be a protection line so maybe the amp section has a fault, and the unit will not turn on to protect the power supply.
          If you have the remote control, try pressing the MODE and HOME buttons together for about 5 sec. and see if you get anything on the display.
          • ccbargains
            • Jan 2017
            • 7
            • usa
            Thank you for your help. I have ordered replacement for Q904.D905 and D906. I will get back to you when i receive them.
            I will try your suggestions R.J. Do you know where I can download a schematic?
            • Bushcat
              Identifying a Pioneer PD-F1007 cap; looking for a PC-to-keyboard emulator
              by Bushcat
              I picked up a Pioneer PD-F1007 300-CD changer very cheaply without the remote, marked as "junk". It's cleaning up very well: most issues seem fixable with contact cleaning, cleaning optics, etc. The series has a reputation for forgetting the immense amount of programming that goes into storing CD details, and it seems to be a common thing to swap out C354, part PCH113 which is 0.1uF/5.5V. However, I can't find out its design discharge rate.
              Others have suggested various EDLS replacements including the Eaton KW-5R5C104-R, but comparing their specs the recommended discharge...
              03-11-2024, 12:45 AM
            • EduCabral
              [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
              by EduCabral
              I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
              While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
              🔧 Details:
              • Model: YT-M06
              • Interface: Pioneer 1
              • MCU: Fujitsu MB89F202
              • Goal: Find a valid .bin firmware file or memory dump from a working unit
              I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
              07-15-2025, 12:26 AM
            • I8jjrnhh4thvtl0dWZoY
              Repair Manual for Bosch SHX55M05UC/46 Dishwasher (702_58300000148618_ara_en_a)
              by I8jjrnhh4thvtl0dWZoY
              Repair manual part number 702_58300000148618_ara_en_a
              It took way too much effort to find this manual so I am sharing it here so the next person can find it easily. Also, I am mad at Bosch for not publishing it on their website, so they deserve to have it leaked....
              07-14-2025, 07:36 PM
              Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
              Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
              various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
              Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
              trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
              what is wrong with your PC in just seconds. It saves you time and money.
              Our new and improved design...
              11-01-2024, 06:29 AM
            • pixelcap
              Pioneer Kuro Pro 111FD 8 red blink error
              by pixelcap
              Pioneer Kuro Pro 111FD 8 blink red LED.
              I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
              So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
              based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
              10-06-2024, 11:26 PM
