Identifying a Pioneer PD-F1007 cap; looking for a PC-to-keyboard emulator
  • Bushcat
    • May 2023
    • 18
    • Japan
    I picked up a Pioneer PD-F1007 300-CD changer very cheaply without the remote, marked as "junk". It's cleaning up very well: most issues seem fixable with contact cleaning, cleaning optics, etc. The series has a reputation for forgetting the immense amount of programming that goes into storing CD details, and it seems to be a common thing to swap out C354, part PCH113 which is 0.1uF/5.5V. However, I can't find out its design discharge rate.
    Others have suggested various EDLS replacements including the Eaton KW-5R5C104-R, but comparing their specs the recommended discharge rates vary from 50 uA to 75 mA.
    On the one hand, I have a user manual which states the unit should not be connected to the switched outlet on an amplifier, presumably because it needs constant power. This suggests the supercap can only power the memory for a short time. On the other hand, an ancient online page at pioneerelectronics.com, says the memory backup is approx. 30 days.
    The two capacitors I have ready access to are the NEC/TOKIN/Kemet FYH0H104ZF and FTW0H104ZF. The FY is rated at up to 500 uA. The FT at up to 50 mA, with a higher self-discharge. So I should pick the FY: less power, for way longer. Or am I wrong??
    Programming the thing: since the initial programming effort is high, and there's a risk the unit will lose its mind from time to time anyway, I'd prefer to load the memory from a PC program via a keystroke emulator and a USB to PS/2 connection. As anyone seen/used anything like this? PC, Pi, Arduino etc. would all be OK with me. Decades ago there used to be a PC controller for the Sony CD changers, but the hardware dongle is long gone.
  • Bushcat
    • May 2023
    • 18
    • Japan
    Wot no edit button? EDLS should be EDLC. PCH113 = PCH1133. "As anyone..." = "Has anyone..."
    • ccbargains
      Pioneer SX-S30 need help identifying SMD semiconductors Also need service manual and/or schematic
      by ccbargains
      I have not been able to locate a service manual for this Pioneer SX-S30 receiver. The unit will not turn on. I am troubleshooting the switch mode power supply. I found three smd semiconductors that test open while in circuit. The first (Q904) is a transistor marked AZ43W. The second is a diode D905 marked L68 and the last is a diode D906 marked 66 CU1M. I have attached photos.
      Any help would be appreciated. Thank you....
      06-30-2024, 11:55 AM
    • Bushcat
      Pioneer PL-X9 motor speed control wobble
      by Bushcat
      I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
      Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
      BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
      05-24-2023, 03:36 AM
    • araxnido
      Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
      by araxnido
      Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
      When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
      06-10-2025, 09:26 PM
    • pixelcap
      Pioneer Kuro Pro 111FD 8 red blink error
      by pixelcap
      Pioneer Kuro Pro 111FD 8 blink red LED.
      I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
      So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
      based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
      10-06-2024, 11:26 PM
    • RatherLoopy
      Pioneer VSX-44 receiver HDMI dropouts
      by RatherLoopy
      I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
      I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
      And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
      05-26-2023, 03:54 PM
