Yamaha TSX 120 Standby Problem
  • psssst
    • Mar 2024
    • United Kingdom
    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco modes and there are none. The display is slightly dim which I understand is a common fault with these units, could the components which fail causing the dim display be affecting standby power use?
    I took it apart yesterday mainly to clean under the buttons under the top panel which are impossible to clean properly without dissembly and to look for anything looking wrong. The radio appears to have been stored in a shed and had both live and dead insects inside it, many cobwebs and areas of spider turds. I cleaned out as much as possible and cleaned the circuit boards I had removed from the top panel. The remaining two boards in the lower part of the unit weren't removed but were cleaned as much as could be reached. They looked very clean. Can dead insects or spider turds affect standby use?
    I'm a complete electronics amateur so please excuse any errors.
  • redbaron1007
    Yamaha HTR-3065 No power/No Standby
    by redbaron1007
    I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
    S9 13.7V
    Pwr Ry 0V
    AC Det 9.1V
    Mgnd 0V GND
    The two pins on the transformer for the operation...
    09-12-2024, 03:04 PM
  • hemant_2222
    Yamaha RX-V373 no voltage on the standby switch
    by hemant_2222
    Could someone please advise on this. I have this Yamaha taken from a friend for repair, especially since it had a USB for my interest. But it is not working at all.
    Here is what has been done so far. Checking the standby switch did not show 3.3 volts on one of its pins, the other was ground. it is showing as 0.60 volts. I have changed the switch as it had some resistance even when normally open. After changing the switch, I next saw that PIN 91 is not showing 3.3 volts.
    The processor clock pin show 2.8 on pin 18 (XOUT) and 0.80 on pin...
    11-29-2022, 11:33 PM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
  • Crystaleyes
    Samsung BN44-00259A standby question
    by Crystaleyes
    Hi all.
    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
    08-11-2023, 05:15 AM
