Crown XLS2002 cooking drivers
  • osoklrs
    Looking for help to understand this problem a little more and what I should be testing for. Crown XLS2002 in bridged powering a Dayton dual voice coil UM18-22 18 inch driver in series at 4 ohms in a custom enclosure. Setup ran well for about 2 weeks then it didn't. The first driver when tested after the failure one coil was at 24 ohms and the other coil at 10 ohms but cone movement is smooth. Got 2nd driver and installed, it cooked right away. Coils ohm at 2 ohms each but the cone sounds crunchy. We believe that unfortunately it is the amp that caused this but I'm looking for advice on what I should be testing the amp for to confirm that the amp caused the failure. Any help is appreciated.
  • petehall347
    • Jan 2015
    • 4448
    check dc voltage across the speaker terminals
    • osoklrs
      Thanks for that I will be checking that next. I suspected this.
      • narf
        Epson EB-U42 projector / Caps with 0.7 ohms ?!
        by narf
        hi all,
        first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
        i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
        what i've found so far:
        - the PSU does its job and supplies 12V to the mainboard via the connector.
        - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
        - not far away, there's the first cap with a resistance of 0.7 ohms....
        07-02-2024, 03:53 PM
      • japlytic
        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
        by japlytic
        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
        Tried (only with keyboard/mouse connected):
        • BIOS + database update
        • Using latest Windows 11 image built with official image creation tool
        • Previous setup version for Windows 11 installer
        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
        06-19-2025, 04:59 PM
      • pavithra
        LC6685 based LED drivers
        by pavithra
        I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
        I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
        Is it possible to get the datasheet of LC6685 IC?
        Also highly appreciate if you could let me know what could go wrong....
        04-16-2024, 02:46 AM
      • kotel studios
        Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
        by kotel studios
        Finally got time to fix this board up.
        At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
        Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
        04-22-2025, 05:08 AM
      • YOUCEF4787
        Installation Issue with AMD Radeon 520 Graphics Drivers on Dell inspiron 15 3576
        by YOUCEF4787
        I am writing to seek assistance regarding a problem I encountered while attempting to install the AMD Radeon 520 graphics drivers on my Dell Inspiron 15 3576 laptop running Windows 10.
        Upon installing the graphics drivers, my system freezes, and I am left with a black screen. Unfortunately, this issue has prevented me from utilizing the full capabilities of my AMD Radeon 520 graphics card.
        Laptop Model: Dell Inspiron 15 3576
        Operating System: Windows 10
        Graphics Card: AMD Radeon 520
        Steps I have taken:
        Downloaded the latest AMD...
        07-08-2023, 05:23 AM
