fender frontman 25r no sound from speaker
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    i have a frontman 25r that has no sound from the speaker, ext speaker jack, or headphones jack but if i put a very high frequency (21470 Hz) into the input jack i can hear it on the reverb if its turned up. the electrolytics are fine so what should i check next?
    Follow the white rabbit.
    Re: fender frontman 25r no sound from speaker
    Here is the SCH
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      thanks for the SCH budm it looks like probing at R14 for audio might be a good start, still pretty stuck on this one
      edit: it looks as if Q1 is pulling it down because on one side of R14 theres audio but on the other nothing but R14 ohms out good, does this sound like a possibility?
        R14 is for the normal level signal that signal is switched in and out by the Gain selector switch, on normal mode Q1 is turn off (High resistance) so the output signal from OPAMP U1-B will flow through R14, R15 to the input U3-A pin2. At the same time Q2 is also off (high ressistance) which will block the high-gain audio stage signal from feeding U2-B, so there will be no output from U2-B to feed U3-A. When switch set to high gain, Q1 is on so it grounds out the output signal of U1-B, at the same time the high gain signal from the output of U2-A will now able to flow through the low resistance of Q2 to the input of U2-B and its output will now be applied to the input of U3-A.
        SO, at this point, do you get low signal from both settings? if you do then we need to look at the output of U3-A and after that signal path.
        Also, if you turn up the REVERB level and shake the cabinet, do you hear real loud reverb spring, it sounds like thunder?
        • Longbow
          • Jun 2011
          • 623
          Originally posted by goontron
          no sound from the speaker, what should i check next?
          The usual plan is to get out your meter and confirm the (+/-) 27v, 15v and 13v. What made you think of plugging a 21KHz signal into the input?
          Is it plugged in?
            If you do not have the scope, then I would use 500 Hz tone about 100mV feeding the input, then set the DMM to AC volt and just probe and see if you will see any output from the Opamp all the way to the R55. You can vary the volume to see the signal goes up and down also.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              i have 15v on each winding of the transformer and tapping the reverb does nothing but today it made the .8watt speaker plugged into the external speaker jack catch fire in my hand after i taped the board and it started buzzing and popping.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                ok so i taped on resistor 76 and it tried to work but at the same time i flexed the board and it went dead this time tapping didnt help
                  If you can tap on the circuit and causes the buzz and popping sound then inspect the board for bad joints, at the same time check the DC voltage at the speaker out put to make sure it does not have large dc voltage on the output.
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    24 volts at the speaker, is that bad?
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      ok the TDA1514A is very bad it just smoked without blowing the fuse and a new revision wont work of the TDA1514A wont work so im just going to throw this one out.
                      • Longbow
                        • Jun 2011
                        • 623
                        Well, just as a retrospective I think that the use of a multimeter and a little circuit contemplation might have saved this unit from a flameout. The output IC is/was definitely shorted as the 24 vdc on the output confirms. Since the power IC is direct coupled, a working amplifier would have 0 vdc on the output.
                        One thing to keep in mind when working with power output stages is that a failed transistor or IC usually takes a number of other parts in the circuit with it. Just replacing one of the faulty parts results in more smoke. We've all been there.
                        Is it plugged in?
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          the TDA1514A is the output IC and the new revision of the IC scaters plastic if you try it. Everything else is fine but i dont want to try and mod it to handle the new IC.
                          • cazi1001
                            Samsung Galaxy A22 - strange problem with sound / speaker
                            by cazi1001
                            I have a Samsung Galaxy A22 5G with a strange error image.
                            If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
                            If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
                            If I listen music via Youtube, even the upper or lower speaker don't work.
                            If I switch louder or quieter, the sign on the screen show me a headphone.
                            If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
                            Does anyone have any ideas, what the problem could be?​
                            02-10-2024, 09:16 AM
                          • Christos Tsiligiannis
                            Marian Trace Alpha sound card repair help
                            by Christos Tsiligiannis
                            Hello to the forum.
                            My name is Christos, I am new to the forum here and i am posting from Greece.
                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                            11-18-2024, 05:26 AM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-12-2024, 02:30 PM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
