Peavey CS80 caps?
  • redrooster
    • May 2011
    • 114
    Peavey CS80 caps?
    Im trying to fix this amp and I'm wondering if the big soup can size caps are kaput (15000uf, 90v.) Ive measured them with a capacitor meter and they seem to be OK,but I haven't measured with an ESR meter? The symptoms are that the rails are supposed to be 78vDC positive and 78vDC negative but it goes from 9vDC to 78vDC and measures 2v 6v 22v on AC as well? Its all over the place,what do you think?
    HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
  • redwire
    • Dec 2010
    • 3912
    Re: Peavey CS80 caps?
    If the main filter caps are bad, you'll get steady hum and low voltage, it won't wander that much. I'm suspicious that it goes from 78V to 2V without some some smoke. Check the thermal switches on the xfmr primary, if the amp overheats it goes into a low-power mode.
    If I remember right, you can unplug power to each channel to see if one channel is loading down the rails.
    I found the schematic here: Peavy Amplifier schematics
    Had no luck fixing one of these, they are a bear to work on and have only one fuse.
    • redwire
      • Dec 2010
      • 3912
      Oops, this amp doesn't have a soft-start, so I'm wrong about the overheat- it just shuts off primary power. Check the bridge rectifier too.
      • redrooster
        • May 2011
        • 114
        Mate Ive checked everything.Ive put in a new bridge,triacs,transistors and replaced all op-amps.it has steady voltage for a while then goes stupid again out of the blue? I just had another go,Ive got 247voltsAC on the primary and 20vAC on the secondary? Looks like the transformer?
        • redwire
          • Dec 2010
          • 3912
          The power transformer is 240VAC primary and 120VCT secondary, or 2:1 for Australia I believe.
          I would check the primary wiring for poor connections. I think it goes BLK/YEL to BLUE, AC input is on BLUE/YEL and the BLK. If the voltage is wandering, it might be arcing somewhere, in the tranny or it's wires.
          These amps are super-heavy 45lbs. and get beat up doing tours of duty on the road, with bands. They usually smell pretty bad, like cigarette smoke and liqueur...
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
