Denon avr-1602 issue
  • gornati
    • 27
    • Brazil
    The other day, i was using my denon receiver, notice a bad smell, shutted everything off.
    Later on, tried to turn on again, but i got no sound and no image thru HDMI, looks like HDMI IN was bad, because On Screen Display was working, volume control and setup menu was showing in the screen.
    Any ideas?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Denon avr-1602 issue
    Any ideas?
    Could also be a power supply issue. Do all the other functions work? Does the device that was sending the HDMI signal into the receiver still work???
    P.S. It would greatly help if you could get us some good, focused pictures
    Muh-soggy-knee
    • gornati
      • 27
      • Brazil
      well i didnt opened the receiver yet.
      and yes, the PS3, XBOX360 and CABLE TV are working fine.
      if i connect them directly in the TV, works fine.
      all functions looks like are working, TURNER (WITH NO SOUND), IPOD dock connector (no sound) recognizes ipod/iphone, search thru the music etc.
      speaker test works fine, WITH SOUND!!!
      what else, protection works (that clicking noise when you turn on and off the receiver).
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Well, sounds like the HDMI interface chip has gone poof. Only one thing to do - open it!
        Muh-soggy-knee
        • gornati
          • 27
          • Brazil
          will do it tomorrow!
          Today i just fixed my 50 inch plasma with helps from this forum!
          Here is the video before:
          http://www.youtube.com/watch?v=bBwp2-VcoP4
          Here is the video after:
          http://www.youtube.com/watch?v=e1Lf6x9HoQg
          • basskilla
            Denon PMA 350SE receiver missing part,need help for rewiring.
            by basskilla
            Hi Friends!
            I have a Denon PMA 350SE receiver,the remote controller-sensor pcb panel is missing from inside and without this it not even powering on by the main switch.
            So there are two connector left one 8 pin and one 3 pin.
            Would be Someone so kind and tell me which pin should connet to where,to make it work?
            I attached the service manual and pictures from the connectors.
            Thank You for the answer,and best wishes!...
            08-14-2023, 02:59 AM
          • benspawn02
            Anthem MRX500 - no sound. R2A15218FP issue??
            by benspawn02
            Dear Electronics Experts:
            I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
            08-12-2023, 04:46 AM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            by ugamazing
            12-17-2024, 07:05 PM
          • Cornito
            Denon AVR-2700H audio stops while receiver still works
            by Cornito
            Hello team,
            I've got a new issue with a Denon Avr-2700H.
            After several minutes working, receiver stops playing sound with a poc eared in the speakers.
            Receiver still work and display video with error message on display.
            Seems to me that is the main output relay.
            I'm looking for the service manual that I can't find for the moment.
            Does somebody have it?
            Regards...
            08-03-2025, 06:10 AM
