home made sound card
  • whiz
    • Aug 2006
    • 48
    Hello i'm new here! i have recently finished a USB sound card
    the device uses the PCM2902 chip and i can say it works good enough!
    (i would rate it 7/10) but as far as i now it can get a little better than that...
    i have loopback tested my PCB with Real Mark audio analyser and these are the results
    frequency Response, db: +0,15, -0,06
    noise level, dbA: -83,8
    dynamic range, dbA: 81,5
    THD %: 0,214
    IMD+ Noice, %: 0,180
    stereo crosstalk, db: -88,0
    And these are i'm after for...
    frequency Response, db: +0,15, -0,05
    noise level, dbA: -85,5
    dynamic range, dbA: 85,0
    THD %: 0,0089
    IMD+ Noice, %: 0,018
    stereo crosstalk, db: -88,9
    the IC can do better than that! the specs say that it can provide ADC SNR=89db and DAC SNR=96db
    i'm sure the designing of the PCB is one factor, but my PCB is full of lelon and capxcon and i believe that is one more reason i can't compite other PCM2902 PCBs
    if someone knows what kind and which brand capacitors i sould use i would like to help me!
  • gonzo0815
    • Feb 2006
    • 1600
    Re: home made sound card
    In Audio Equipement, some purist like to use some Solid Polymer caps, e.g Oscon. This is not only due to their very low Esr, some of those are using OFC coper leads, wich will help in reducing the ESL and may be doing some magic HIFI woodo.
    Then there are some specially audio caps, with some zinc or thinfoil. But i don`t know if that is good for anything. I personally would try some good low esr long endurance caps from an respectable brand (e.g. Rubycon, BC, Panasonic) an test it. If there are some improvements, may be those Oscons are worth a try. But in generally, i am not shure, if those bigger caps are the problem. May be there are some smaller decoupling caps missing. But for that, i leave it to the more knowledgeable people here.
    • whiz
      • Aug 2006
      • 48
      thank you for your answer! i partially improved the performace by
      changing usb cable! yes! that's right!
      i've tasted it 3-4 times and all results are almost the same!
      Frequency response, dB: +0.15, -0.06
      Noise level, dBA: -84.4
      Dynamic range, dBA: 81.1
      THD, %: 0.097 (!)
      IMD + Noise, %: 0.173
      Stereo crosstalk, dB: -88.0
      IMD at 10 kHz, %: 0.135
      • Logistics
        • Apr 2007
        • 721
        I'm looking at the datasheet for the PCM2902, right now. What type capacitors and what values did you use for C9, C10, C11 and C12?
        Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
        • LEECH666
          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
          by LEECH666
          Good day ladies and gentleman!
          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
          01-19-2024, 05:46 PM
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:30 PM
          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
