Anyone know where I can order parts for an Integra 50.1? Thank you
Onkyo Integra Parts?
by Tom_xHi friends!
I'm looking for schematic diagram for Onkyo grand integra A-G10 (A-8890)
speaker relays not activated, maybe protection circuit blocking.
If i power on for a minute, and power off and on again, speaker relays activated and unit working.
thx
Tom-
12-02-2023, 01:30 PM -
by RolinI have an Integra DBS-50.2 Blu-Ray Player that I haven't used in a while. Tried to turn on and it turned on for a brief moment with "hello" on the display then shuts off. Dead from that point on unless I unplug it and try again. Took it apart and checked a few well labeled voltages on the Power Supply board and found the 3.3V isn't measuring on the board (unless I'm misunderstanding what I'm measuring). I have a few pics of the board and schematics. There's a 4 PIN voltage regulator at location IC1301 with a part number 070XFC1 by Sharp that I believe should output 3.3V on PIN2,...
by H HHello,
I'm hoping someone could help me confirm if I have identified the following parts correctly.
Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
The parts needing replacement are on the back of the board behind the HDMI input.
I have identified the parts as the following:
C6037: MLCC 0.1uf/16v(0402)x7R W05
R6016: RES 499 OHM 1/16W (0402) 1%
LB10911: Ferrite Bead (0402)...5 Photos02-16-2025, 01:09 PM -
by SiskoHi all!!
Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...4 Photos-
by Mark DThe TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
- Loading...
