Vox mini 3 amp
  • Maranelloinred
    • Apr 2016
    • italia
    #141
    Re: Vox mini 3 amp
    the envelope arrived this morning, I just finished installing it and now everything works perfectly!!!
    Thanks for everything you have been very kind and helpful.
    • midibob
      • Nov 2008
      • 285
      #142
      Re: Vox mini 3 amp
      My pleasure.
      Ciao
      Bob
      • Ninilium
        • Jul 2016
        Re: Vox mini 3 amp
        Just picked up one of these amps for a Song. ($2)
        Seems the power board is only passing 2v.
        Are there schematics available for the Mini3 PCBs?
        What is the output of the Power PCBS suppose to be?
        Thanks in advance.
        • midibob
          • Nov 2008
          • 285
          #144
          Re: Vox mini 3 amp
          $2, you did well there.
          There are still no schematics that I'm aware of I'm afraid.
          The regulator should put out 5v, I forget what type of device it is now but I do remember it's a common part.
          • fth
            • Jul 2016
            • Nederland
            #145
            Re: Vox mini 3 amp
            I bought this beauty second hand for my cigarbox guitar and I must say that it sounds very good. But I have a problem with the mic input. When I put a mike in the Mic jack I have feedback. Even when I turn the trim on minimum I still have feedback. It looks to me that the trim is not working as it should. Can you tell me does the sound goes to zero when you turn the trim on minimum?
            Kind regards to you all
            Frans
            • midibob
              • Nov 2008
              • 285
              #146
              Re: Vox mini 3 amp
              If you're using a cheap condenser mic the output level will probably be too high.
              The trim doesn't cut the volume completely. Most reasonable dynamic mics I've tried it with are fine.
              • fth
                • Jul 2016
                • Nederland
                #147
                Re: Vox mini 3 amp
                Thanks a lot for the answer Midibob. I'm glad that it is not a misfunction of the trim. I'm going to make a pot at the back of this little beauty. I followed this thread bcause I was very curious to the solution of the fried amp IC and I think you did a great job to develop your daughter board. Thanks for charing this.
                Kind regards Frans
                • BarryP
                  • Jul 2016
                  #148
                  Re: Vox mini 3 amp
                  Hi MidiBob
                  I'm trying to fix one for a friend. can you send cost/order details of your daughter-board please.
                  Cheers,
                  Barry.
                  • midibob
                    • Nov 2008
                    • 285
                    #149
                    Re: Vox mini 3 amp
                    PM sent.
                    • radoslavv
                      • Aug 2016
                      • Slovakia
                      #150
                      Re: Vox mini 3 amp
                      Hi midibob,
                      I have same problem like nearly everybody in this forum thread - this times from Slovakia. Could you pls PM schematics and pcb layout?
                      Thank you,
                      Rado
                      • midibob
                        • Nov 2008
                        • 285
                        #151
                        Re: Vox mini 3 amp
                        Hi Rado,
                        As far as I know there are no schematics available for the Mini 3.
                        Midibob
                        • radoslavv
                          • Aug 2016
                          • Slovakia
                          #152
                          Re: Vox mini 3 amp
                          Hi midibob,
                          I thought your daugter board.
                          Rado
                          • midibob
                            • Nov 2008
                            • 285
                            #153
                            Re: Vox mini 3 amp
                            There is a picture earlier on in this thread, I don't have a schematic as such as it's so simple.
                            • radoslavv
                              • Aug 2016
                              • Slovakia
                              #154
                              Re: Vox mini 3 amp
                              Hi alltogether,
                              Who is interested in board details before/after IC3 desoldered from VOX Mini3 board, could find details attached. I have used hot air desoldering tool.
                              Even this tool used, it is hard to avoid board destruction - see IMG_5288 how pads moved . Unintentionally R23 of value 10^3 was blown from it's position, so I have to solder it back using smd soldering iron (can be seen difference on IMG_5284 and IMG_5288 - value text is rotated).
                              So pay attention and have a good tools to do IC3 removal job.
                              Later I will come back with soldering of IC3 replacement (waiting for delivery).
                              Rado
                              • midibob
                                • Nov 2008
                                • 285
                                #155
                                Re: Vox mini 3 amp
                                Hi Rado, I wish you luck in replacing IC3. I have done it but it's a real pain.
                                For removal, one tip is to use an under board pre heater at about 150C and then use the hot air gun on top. This reduces the chances of the pads coming unstuck due to too much heat. The chip can then be removed quite easily without causing any damage.
                                • Leandrom
                                  • Nov 2016
                                  Re: Vox mini 3 amp
                                  Hi Midibob, I have this Amp with the same issue. Can I take it to your home for repair? unfortunately I don't know how to fix it myself. I'm happy to pay you.
                                  Many thanks
                                  Leo
                                  Originally posted by midibob
                                  Been grappling with this one for a while and no success so far.
                                  These little guitar amps are rated at 3W and are quite nice, good sounding busking or bedroom amps.
                                  I have a number of these with blown output chips and thought they would be quite a simple repair!!
                                  On inspection I found that the chips were micro smd 9 ball WLCSP types. They are 1.2mm square and you need a microscope to see them.
                                  Trouble is the type code bears no relevance to anything I can find. No IC manufacturers I've contacted so far have been able to identify the type number 'BP27'.
                                  There are so many of these class D amp devices available with different specs and gains that it's impossible to guess which one would be the correct replacement.
                                  I've tried the Vox forum with no joy either. Schematics are non existent too.
                                  Pity it's not dodgy caps, easy stuff in comparison.
                                  Midibob
                                  • midibob
                                    • Nov 2008
                                    • 285
                                    #157
                                    Re: Vox mini 3 amp
                                    Hi Leo, I'll PM you.
                                    • willem59
                                      • Nederland
                                      #158
                                      Re: Vox mini 3 amp
                                      Hi Midibob, I have this Amp with the same issue.* Do you still ship these boards?
                                      • midibob
                                        • Nov 2008
                                        • 285
                                        #159
                                        Re: Vox mini 3 amp
                                        PM sent.
                                        • mirco.nardini
                                          • Jan 2017
                                          • italy
                                          #160
                                          Re: Vox mini 3 amp
                                          Ho Midibob, can you ship the board also in Italy, I need one
                                          Ciao and thank for you reply
                                          Mirco
                                          • ugamazing
                                            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                            by ugamazing
                                            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                            08-31-2022, 07:34 AM
                                            HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                            This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:36 PM
                                            HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                            This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-12-2024, 02:20 PM
                                            09-12-2024, 02:15 PM
                                            HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
