Vox mini 3 amp
  • tk5320
    • Mar 2014
    Re: Vox mini 3 amp
    Hey midibob, looks like I have the same problem as everyone else. Can you send some help. Thanks, Taylor
    • midibob
      • Nov 2008
      • 285
      #62
      Re: Vox mini 3 amp
      Hi Taylor.
      No problem I'll send you a PM.
      • craciun
        • Apr 2014
        • Ireland
        #63
        Re: Vox mini 3 amp
        Hi midi Bob,
        I have the same problem with my amp. Any chance of you sending me a schematic of your daughter board. Solution.
        Thanks in Advanced.
        Craciun
        • midibob
          • Nov 2008
          • 285
          #64
          Re: Vox mini 3 amp
          Hi Craciun,
          I'll send you a PM.
          • Microamp
            • May 2014
            • 5
            Re: Vox mini 3 amp
            Hi midibob,
            I think my mini 3 is starting to go, too, but isn't completely blown since I still get a badly distorted sound out of my speaker. I tested the speaker alone with another amp and it's fine. The output from the headphone output is also normal. Since the output chip is completely blown, my resistances are okay. Do you think it could still be the chip or did I blow something else?
            Thanks,
            Microamp
            • midibob
              • Nov 2008
              • 285
              #66
              Re: Vox mini 3 amp
              Hi Microamp,
              I must admit I haven't come across one yet that has been badly distorted. Usually the chip just blows. You could just confirm that the 5V rail is OK that feeds the chip. It's supplied from the surface mount 3 pin regulator chip IC9.
              Midibob
              • Microamp
                • May 2014
                • 5
                Re: Vox mini 3 amp
                Hi midibob,
                I hope I checked it right. I'm a bit if a novice with a circuit so small and complex. I got over 5v at pin 3 on ic9 and about 9v at the speaker leads. That makes sense since I do get sound. The sound is just buzzy in a bad way, especially on BTQ Clean which was so clean before. It almost sounds like a capacitor is not working to filter out the noise. Are there other tests I could check? My experience is limited (built some small simple circuits like ruby, little gem, and punch amps), but I'm willing to learn.
                Thanks,
                Microamp
                • midibob
                  • Nov 2008
                  • 285
                  #68
                  Re: Vox mini 3 amp
                  That doesn't sound right?
                  You should only see half the supply voltage between the speaker terminals and ground. Being as the chip should only be fed with 5V you should measure approx 2.5V. Where are you actually measuring?
                  • Microamp
                    • May 2014
                    • 5
                    Re: Vox mini 3 amp
                    I did measure it wrong the first time. This time I'm taking ground from the master volume potentiometer and do get 5V from ic9 and 2.5V from each speaker lead. I was mistakenly using ground from the power switch. Thanks for bearing with me.
                    • midibob
                      • Nov 2008
                      • 285
                      #70
                      Re: Vox mini 3 amp
                      No problem, the grounds on these little beasts aren't where you'd expect them!
                      It does sound like the chip is playing up. Have you tried running it from batteries. In theory it won't make any difference and I think then you can be certain it's the chip.
                      • Microamp
                        • May 2014
                        • 5
                        Re: Vox mini 3 amp
                        Yeah, the problem is still there even with batteries. Any other thoughts on diagnostics? Aux in with a MP3 player sounds clean, as does headphones with the guitar input. The mic input is buzzy like the guitar input. If your daughter board replacement chip isn't too hard of an install and is reasonably price to send across the pond, I'd be willing to give that a shot. Otherwise, I may end up with lots of spare parts to salvage to build another ruby or chime/punch amp and maybe install a 6 inch driver in the cabinet for better tone. PM me with details if you want to keep business off the message board.
                        • midibob
                          • Nov 2008
                          • 285
                          #72
                          Re: Vox mini 3 amp
                          On these amps the headphone output is before the chip so if all is well there then it further confirms the fault to be the chip. Not sure I understand when you say the Aux in sounds clean? Do you mean that the output isn't distorted at all as if so then it could be something else. All seems a bit unlikely though as it all uses the same path!
                          Sent you a PM.
                          • Microamp
                            • May 2014
                            • 5
                            Re: Vox mini 3 amp
                            I checked the aux in and it is slightly distorted when I have the MP3 player output volume higher. I guess it wasn't as noticeable when it was lower. The guitar input though is very noticeably distorted when it should be clean (btq clean or line). I guess what still confuses me why I have any sound. It's almost as if the gain stage is bad. When the gain is really low and the master volume is down, it's almost clean. Then again, maybe it's just too quiet to hear the breakup.
                            • midibob
                              • Nov 2008
                              • 285
                              #74
                              Re: Vox mini 3 amp
                              Hmm, so it all sounds a bit inconclusive.
                              I'm still unsure what you are seeing at the headphone socket? Is everything clean there, guitar and Aux? When I test these I use a signal generator so I know what levels I'm putting in to the amp. That way comparisons are easy.
                              • Paul_5
                                • Jul 2014
                                Re: Vox mini 3 amp
                                Hi all, I've got one that does the same. Are there any daughterboards going spare?
                                • midibob
                                  • Nov 2008
                                  • 285
                                  #76
                                  Re: Vox mini 3 amp
                                  Hi Paul,
                                  Are you able to PM me as I'm unable to send you a message. If you can let me have your Email address I'll forward you the details.
                                  Midbob
                                  • Paul_5
                                    • Jul 2014
                                    Re: Vox mini 3 amp
                                    Will do Midibob.
                                    • jobo
                                      • Sep 2014
                                      • ireland
                                      #78
                                      Re: Vox mini 3 amp
                                      Hi Midibob,
                                      do you have any more of those daughter boards available, I am new to this site and unable to pm you many thanks joe.
                                      • midibob
                                        • Nov 2008
                                        • 285
                                        #79
                                        Re: Vox mini 3 amp
                                        Sure, I'll PM you.
                                        Midibob
                                        • dude.770
                                          • Sep 2014
                                          • usa
                                          #80
                                          Re: Vox mini 3 amp
                                          midibob I need info on getting a board for the mini3 . thanks
                                          • ugamazing
                                            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                            by ugamazing
                                            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                            08-31-2022, 07:34 AM
                                            HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                            This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:36 PM
                                            HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                            This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-12-2024, 02:20 PM
                                            09-12-2024, 02:15 PM
                                            HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
